omidimo
Well, if would great if there was a multi purpose modern case option for 800/840AV/8100/8500 motherboards a la the Amiga 3000 Kickstarter run. Imagine not having to worry about breaking plastic.
There isn't much you can do with spare motherboards and power supplies since they won't fit into an off the shelf case.Well, if would great if there was a multi purpose modern case option for 800/840AV/8100/8500 motherboards a la the Amiga 3000 Kickstarter run. Imagine not having to worry about breaking plastic.
I'm around 85% sure you can put the 8600 motherboard into a 7000-series case.Now what exactly can you do with an 8600 MB and PS since they won't fit in anything but a mac 8600/9600 case and finding one of those is pretty difficult
That if this happened, it would or could hypothetically have utility for a lot more than just the 8-series macs. Heck, if you made it oversized, you could do like the 8600 and put a 3-slot board in a case obviously meant for six slots, to be able to put 9500 and 9600 boards in it.Well, if would great if there was a multi purpose modern case option for 800/840AV/8100/8500 motherboards a la the Amiga 3000 Kickstarter run. Imagine not having to worry about breaking plastic.
I was thinking of a recreation of the Radius case as it is a tank, and that different drawers could be added for additional board layouts. If one wanted to have a 9x00 in there too, then we are talking a little more DayStar Millennium/Genesis. I think such a thing would need a modified modern PSU to replace the older design for better thermal management. What the Amiga guys have been doing with new cases is pretty smart.That if this happened, it would or could hypothetically have utility for a lot more than just the 8-series macs. Heck, if you made it oversized, you could do like the 8600 and put a 3-slot board in a case obviously meant for six slots, to be able to put 9500 and 9600 boards in it.
I've been playing with a big Dell proprietary "ATX form factor" case. 9500 board's about 1.5" too wide to fit. 8600 board just fits, but they're a bit too deep to be sure about clearing any junk mounted behind the front bezel's frame. Depends on height differentials.My thought was basically, bigger 8600/9600 sized case, or full ATX sized case into which you could mount any of those motherboards, and the smaller boards would leave a bit of space at the bottom, which you could do things like "extra drive trays" (which the 8600 case does, for exaple.)
That's intriguing, and good to know, and I kind of suspected, but isn't necessarily a solution, since a lot of the machines in the IIcx/ci/vx/vi/P600/Q700/C-Q650/PM7100 form factor (I'm sure I've missed one) are themselves either uncommon relative to the group of Power Macs that have good boards but bad cases, or are themselves well liked enough to merit not encouraging cutting up their cases en masse.7600/8600 boards fit in the IIcx form factor cases though, gotta adapt a new power supply to fit in the Apple can..
I think the power button is in different spots on both but if yo want to recase a MB you could just connect a momentary switch from the case directly to the board.Unless someone has already done this: At some point, I'll pull apart my 840 and 8600 next to each other and see if it looks like they're compatible. The 840 through 8500 is pretty much a slam dunk on that front. (Or: you think the service-source docs would give good enough insight. Those docs reveal you can pretty much pop an 8500 board into an 840 case, so they might have good 8500/8600 comparisons too.)
Today, I'd probably only do that with a busted or marked up case. I've had the Quadra 700 triplets to play around with for a dozen years or so. One will remain forever stock with backup logic boards and a PSU. I wanted to have five total and with I consider the three most worthwhile generations of processors spread across the triplets that used to hold up the shelf surround of my plotter.That's intriguing, and good to know, and I kind of suspected, but isn't necessarily a solution, since a lot of the machines in the IIcx/ci/vx/vi/P600/Q700/C-Q650/PM7100 form factor (I'm sure I've missed one) are themselves either uncommon relative to the group of Power Macs that have good boards but bad cases, or are themselves well liked enough to merit not encouraging cutting up their cases en masse.
Yeah, it's absolutely not something I'd have the money to back right now, even though I have an 840 and a 7300 and a beige G3 desktop that I think getting replacement cases for would be great and fun.Cases won't be cheap, but laying something out in AI to house some of my boards might be fun
Mounting a board with standoffs isn't that much of a headache, drilling out the standard placement AT/Baby AT/ATX standoffs is the problem the way I see it. Hole placement patterns in printable PDF for the different Mac boards to line up with the drilled out ATX standoffs would probably suffice. Not sure you could use a plate in between anyway?Thinking about different options and considering what all features the community needs and what can be eliminated to save cost is important. If a pre-fabbed mounting plate to run a Mac motherboard in a stock ATX case is possible, that might be the most economical option and we can just let people choose what kind of ATX case they want.
