So I attempted the Carrera in an SE/30 this evening with the MicroMac PDS adapter. I received identical results as Von.
All of the control panel versions (original unpatched, and both patched versions) opened just fine, but the controls had no affect on enabling the 040. System remained at 16Mhz 68030 regardless of selector switch positions.
Placing the extension to the system folder and rebooting causes a bomb whilst loading extensions, regardless of which control panel is accompanied:
So, the extension will need serious attention.
I was reading the Carrera040 Update Notes, and there is this:
STEP 3: Install a Universal System
Use your System installation disks and do a "Custom Install for any Mac". DO NOT install a minimum System OR the System for your particular Mac. With Installers prior to 7.5 you can shift click to select multiple options (such as printers and networking) at the same time.
STEP 4: For Mac IIx and IIcx only.
Install Mode32 Mode32 is located on the Utilities disk provided with the Carrera040.
So testing should be done in that environment.
Also, more problems are bound to be had. Later on, the notes caution with this little gem:
◊ Graphics cards in slot E: If you have trouble booting up your Mac IIci with a Carrera040, and you have a NuBus graphics card installed in slot E (the NuBus slot closest to the power supply), relocate the graphics card into another NuBus slot.
Of course, the SE/30 native video is located at slot $0E.
Tomorrow I shall try the IIcx adapter in my socketed logicboard, but I seriously doubt we'll get any further.
EDIT: Well, scratch that. The IIcx adapter blocks the power connector. I could remove it and solder an extension directly to the logicboard, but I’m not sure I’m that determined. I’ll sleep on it.
