Calling anyone with a working Color Classic and a Multimeter
willmurray461
I just recapped my color classic, but it still doesn't work. After reading an older post here, I noticed that Y1 was disconnected from C56 due to a bad via. However, I had a little soldering accident and destroyed one of the traces/vias coming off of C56. Does anyone have a working color classic motherboard and a multimeter that they could use to probe out where that trace goes so I can make a bodge wire?
willmurray461
I've already looked at the Bomarc schematics, and either they are for a different board revision, are erroneous, or I'm not reading them right. It says that the left leg of Y1 connects to C36 (it should be C56) and R36. However, it makes no mention of the third trace I'm trying to figure out...
bibilit
in other words, you want to know where the left pad of C56 goes ? probably to the trace you see just underneath... but i will check anyway
IIRC the right pad of C56 goes to ground.
willmurray461
I broke off the circular pad at the end of the trace underneath, and it doesn’t seem to go all the way through the board like a normal via so I don’t know where that pad goes.
SuperSVGA
It definitely appears to go to ground on my board.
It does not appear to be a blind via either. I can see the two vias below C56 match up with the two under Y1. The blind vias appear to be plated/plugged.
SuperSVGA
Sorry, I thought we were talking about the right side connection of C56. That one is a blind via, so it's hard to tell, but I'm guessing it goes to R37 since there doesn't seem to be anything else connecting it.
willmurray461
That pin of the oscillator is already connected to R37 via another via… My hope is that you’d just be able to blindly probe around with a multimeter in continuity mode to see if you can find a beep…
bibilit
Ok, so your pad is connected to the the left pad of C56.
The same pad goes on the other side of the board, and is connected to right pad of Y1.
willmurray461
I already got that part down. I’m actually trying to figure out the same in reverse, i.e. aftet leaving Y1 and going to the left side of c56, where does it go after disappearing into the blind via?
willmurray461
I'm pretty sure the via above R37 connects through on the other side directly to one of the pins of the oscillator. It also still has continuity on my machine, even though the blind via is gone, so I'm assuming the blind via goes elsewhere. Honestly, I'm beginning to think that blind via might not go anywhere. I couldn't find anything by trying to dig around the trace, and its possible that another via elsewhere was destroyed by leaky capacitors and is the cause of my problems. Either way, if we can't fix the problem that's fine as I was planning on turning this machine into a TAKKY anyway.
SuperSVGA
I can't see anything missing from the schematic though.
You have:
  • R37 - Feedback Resistor
  • R36 - Isolation Resistor
  • C56 and C50 - Load Capacitors
  • U7-3 and U7-4 - Out and In
  • Y1 - Crystal
Typically that's all you need to use a crystal like this.
willmurray461
That's why I'm confused. Why have a trace+via that doesn't go anywhere? At first, I just thought it was possibly due to the fact that the schematics were reverse engineered, and thus possibly incomplete. However, it doesn't seem that way...
SuperSVGA
It might actually just be a test pad rather than a via. I fiddled with mine a bit, and it seems more like a flat disc that just lifts right off the board.
willmurray461
That’s pretty much what I experienced. Guess that settles it, it’s probably a test pad. I guess I need to look around for more corroded vias then near the other capacitors then.
