I wasn't sure where to post this as this spans Mac categories (these drives came from a II-series, Portable, and SE/30).
I have 3 drives that are dead and am wondering if any of them are likely to be fixable, or if I should just toss them and not spend hours on a futile effort.
Two of them exhibit the same symptoms -- they seem to work (but need a head cleaning), but will not eject. I would suspect the infamous eject gear, but I don't hear any indication that the eject motor is even spinning. Is this some simple fix, like a capacitor that needs replacement or something?
The third is a drive that is very dirty and needs serious cleaning and lubrication, but also makes a constant hum when the Mac is powered on, with or without a disk. The drive motor does spin, however. Any ideas?
