powellb
Colleagues,
I have been running my SE/30 with GW ROM installed (using standard IIsi) and Bolle's Carrera040 clone without issue for some time. I have been using TMON Pro as my debugger, but now that I am doing some development on this machine as well as on a PPC machine running OS9, I wanted to use the same debugger. So, I switched back to Macsbug (which is what I had used 40 years ago).
To my surprise, Macsbug won't work on my SE/30 configuration. I boot a fresh System 7.1 install with Carrera040 drivers and Macsbug. On boot it says "Debugger Loaded"; however, once booted, triggering the debugger, I get the standard Macintosh monitor (> prompt).
I removed the Carrera040, and Macsbug works just fine. I have tried Macsbug versions 6.2.2, 6.5.3, and 6.6.3. I think TMON Pro works because it is loaded after Carrera040; whereas, Macsbug is loaded prior.
It would seem to me that the Carrera040 driver overwrites trap to invoke Macsbug, putting it back to the ROM monitor.
Searching the forums (maybe I missed something), I can't find anyone else with this issue, so I want to find out if others have this issue.
Edit: add Macsbug versions.
