rjkucia
This is a continuation of an old thread: https://tinkerdifferent.com/threads/macintosh-se-wont-boot-system-7.792/
tl;dr - Booting System 7 off of my BlueSCSI didn't work. I got a RaSCSI instead, and that worked.
Since then I put the BlueSCSI away and didn't think about it too much. I've upgraded to an SE/30 board in my SE, and have been pretty happy with the RaSCSI. I wanted to try out the BlueSCSI again and see if I was still having the same issues. Using an image containing 7.5.3 that is confirmed to work when booting from my RaSCSI, I got a "bus error" bomb during boot. I've tried multiple SD cards with similar results.
Since the common denominator at this point is the BlueSCSI itself, what would you all recommend for starting to troubleshoot?
