Hello to all,
I have the following problem:
I need a pre-formatted image file for my Powerbook 1400.
I want to use an SD card in the Powerbook, with a storage volume of 64 gigabytes. For this I need an image file with 60 gigabyte size, on which I can install MacOS 8.6 in Sheepshaver. Then I would write the image file to the SD card with balenaEtcher.
I have already tried to create such an image file with dd. Unfortunately I was unsuccessful. The file is only recognised as a 1GB volume, although the image file was larger.
On Macintoshrepository you can find ready-made image files. Unfortunately none with 60GB and HFS+.
I would really appreciate it if someone could help me out. By the way, I use Windows 10.
Blank hard drive disk images (100MB HFS up to 30GB HFS+) - Macintosh Repository
All these download files consist of extremely compressed empty disk images for emulators (such as SheepShaver or Basilisk II) that are to be used as...
www.macintoshrepository.org
