A SCSI Zip drive is very high on my want list! I’ve already got a usb one, so that will make file transfers super easy!
Me too! Although I think I'd be more of a Jaz man more than anything else.
I have a SCSI2SD so it's already pretty easy to transfer things back and fourth between my Compacts and later PPC Macs. I have an iMac G4 running Tiger (It's the most recent *working* machine I have that can read and write to "standard" HFS) as well as a USB to SD adapter. I use my SCSI2SD mainly for backups. It's the best way to make a proper bootable image of an old hard drive I think. It's so easy and it's faster than the Floppy EMU for large file transfers.
Anyway, I'd like to get hold of one some day, just for funsies.
The .image file ought to be ok if it isn't used and never leaves a Mac environment
OK. So that doesn't concern me then... By 'Mac environment', you do mean classic MacOS and OSX/macOS, right?
(In other words, you can't format a disk as 400k, use it in a 400k machine and then later re-format as 800k and expect it to work?) As far as I know a previously used 800k disk can be reformatted and used as 400k with no problem. And I haven't had a problem moving 400k disks back and forth between machines.
It'll work just fine for quite some time but if you use that disk with a 400k drive too much, that felt WILL damage/demagnetise the top part of the disk. It won't happen immediately, it'll happen overtime. I think but don't quote me on that, that those
early 400k disks had a different type of coating on the top. Since it wasn't meant to be used, I guess they saved a buck by not covering both sides. That's why you can't format them as 800ks. Not all of them are like that though. And the 400k disk was quickly phased out. It lasted what, two years, right? And was used by the 128k, the 512k, the Lisa and the Atari ST only...
I have been seeing a lot of floppy disk failures lately
Me too... That's really depressing. But for me it's not only the old stuff. I have floppies from the early 2000s that went bad as well!
The worst part is when your disk damages the heads. And you can't really tell beforehand which ones will do that! I should get a standard PC drive just to check that. Would hate junking an original Apple drive...
We're getting a little carried away here. Sorry PB145B for slightly highjacking your thread...
