jefframsey
Is there a separate volume control for the audio port on the back? My internal speaker is not working and so I thought I would see if it is the audio chip or the traces or just the speaker connector, which is really loose in my machine. So I plugged my headphones in and booted up the Mac.
"BOOOOOONNNNNNGGGGG!!!!!"
The volume about killed my ear drum! As soon as it got booted up I went to control panel expecting the volume to be up to 11 (Spinal Tap!!!) but it was only on three. No matter where I set the volume it was the same. The only tim it was better, was when I turned it to 0, which muted the volume all together.
So is this because my machine is not working correctly, or because there is another volume control for the audio jack, or is it normal behavior?
