I recently bought an Asante Maccon for se card and I can’t find the drivers for it, if anyone knows the software for this card can you comment so I can download the software
i Think this is the bin file I downloaded for my SE/30 maccon I think it also includes drivers for other versions as well.?maybe?
I recommend reading the readme file it suggested disabling my extensions for installation by holding shift while booting and also after installing I had to shut the computer off and back on instead of just restarting for it to work I THINK. It also comes with a testing utility that should show if it's working or not.
To get started: Installing A Maccon Card In A Macintosh Se/30 – Asante MacCon Family Ethernet Network Cards For The Macintosh Installation Manual [Page 29] Installation manual: [WayBack] 970…
Asanté Ethertalk Installer 5.1.2 Asanté SNMP MacAgent MacTCP 1.1.1 for System 6.0.7 MacCon Ethernet card EN/SC SCSI-to-Ethernet Mini EN/SC SCSI-to-Ethernet SIT file (1.5.1) and Disk Image --------------------------- Release Notes for EtherTalk Installer 5.1.2 The following is a summary of...
