Apple TV/ Video System bracket
RadRacer203
Just got my TV/Video System out of storage to put in my Powermac 6500, and it turns out it wasn't as complete in box as I thought. Everything seems to be there aside from the bracket that clips into the rear of the 6500. Just wondering if anyone happens to have a replacement or knows of a file I can 3d print instead. I was also curious if anyone knows what that internal connector is for.
bibilit
Connector on the upper right ? video in (IIRC) you have a corresponding connector in the Logic Board.
RadRacer203
Well, I'm stupid. It doesn't need a bezel at all lol. Guess I'll read the manual for what that connector is
Byrd
I think that connector fitted a small Apple branded MPEG-1 accelerator board, but nobody used it as the CPU and graphics could shift full screen video by that time.
RadRacer203
Huh, that's really interesting. I won't be using it though, I already have the pci slots filled with a voodoo 2 and usb
Trash80toHP_Mini
NIGHT STALKER
The board you're holding, as does the box with the credit card remote, and PCB copyright looks like what was released with the Quadra 630 system. So it has the narrow 34pin DVA Connector anyway? That card will work with anything from Q630-6500 without problem, but you need the wider 60pin DAV connector for use with the PCI based AVID kit linked above if that was your wont. VidCard and USB cards you've chosen are better suited to that machine I think.
Apple MPEG Media System is for use in the 040 based 6xx series' PDS Slot. It has the narrow DVA cable setup. It was for MPEG1 playback and PhotoCD as I recall. Played with it last about 10 years ago?
edit: looks like an adapter cable kit was available to use the older DVA boards like yours with the DAV/AVID Cinema Card in your 6500.
