Hi, I’m trying to get my Adjustable Keyboard to work.
Apart from the usual flakey keys, the separate Nummeric pad isn’t working. I’ve only found one set old instal disks for the keyboard on Macintosh Garden, but it will not install on my system.
I’m running a Colour Classic Takky (6500 MB) with System 8.6. The keyboard is recognised in System Profiler and the mouse connected through the Nummeric Pad is working. The adjustable keyboard should work on any ADB Mac, shouldn’t it?
Should the correct drivers be included in system 8.6?
Does anyone know a use for the Record button?
Kind regards from Norway
