Hi All,
I've had the pleasure of owning an SE/30 for a couple years now, and like so many others the HDD gave up the ghost, and like many others, I opted for a V5.1 SCSI2SD adapter. It took a while, eventually I opted for a patched 7.5.3 boot disk, but no matter how I adjusted the configuration of the adapter in the SD Utility, no luck. Pining over this fact later I was struck with how stupid it was that I kept assembling and disassembling the SE/30 to access the SCSI2SD adapter, why not use my Quadra 800 which is nice, roomy, and so easy to disassemble? Here's where it gets weird.
The patched software instantly recognized the SCSI2SD drive, carried out a low level format, I even partitioned it with no problem. I then loaded System 7.5.3 and was ecstatic thinking "YES! now I just re-install it in the SE/30 and we're good!" only we weren't, I was back at square one with a blinking disk with a question mark icon. At this point I remembered I had the motherboard from a salvaged SE, and for my own curiosity I swapped the SE/30 for the SE, and attempted to boot off the SCSI2SD adapter. Worked without incident.
I did search the forum archives, but while I agree the naming scheme is something to revisit (though the fact that it registered for the SE makes me think this is a rabbit hole worth avoiding) I'm of the mind that there's something not right on the SE/30's motherboard. which is why I've started a new thread as a new member, normally a taboo for which I preemptively apologize.
the SE/30 motherboard has never been recapped, I pulled the leaking CMOS battery long ago, and visual inspection tells me, yep, it's a motherboard (no obvious leaking caps which just means no obvious leaks.) I'd love to believe this was a common issue, but I suspect my multimeter and I are going to become very familiar with the board, I'm just hoping someone might have some insight on where to start (other than re-capping, while I'd like to do that myself, my past attempts with FM radios have shown while I can solder, the results leave much to be desired.) Having spent four hours a night daily for the last week, I'm close to banging my head against the wall. It was fun however working between my MBP, a Hackintosh with Snow Leopard that played better with my USB Floppy adapter, the Quadra and the SE/30 at once.
