sutekh
I purchased a dirty and untested Sony 800K mp-f51w-23 (I think it came out of an SE) as an internal drive replacement for my 512K (which is running Plus ROMs and a MacSnap).
After thoroughly going through it and cleaning / re-lubricating, the carriage movement is nice and smooth, but when connecting and powering, the head movement stepper motor just runs continuously:
View attachment Project 1_New.mp4
I didn't test it before before disassembly, so not sure if this was a pre-existing condition or not. I DID modify the ribbon cable that came with the drive by removing pin 9 and 20, thereby simulating the yellow striped cable a Plus would need for this type drive.
I'm thinking the drive controller is probably cooked, but before trying to source another one, figured I'd see if anyone had seen something similar before and resolved?
