pb3623
I have a 950 that has been the most stable machine in my arsenal, just sitting there, serving up files from within A/UX. I also maxed out the RAM to 256 MB and threw a NuBus Ethernet card and SuperMac Thunder/24 card in (since I can't get my hands on the usual 950 "hen's teeth"). Well, I had an issue after swapping video cards (to troubleshoot an equally-frustrating issue with my 700 - see other thread in Peripherals) and, while I managed to get it back up, I have the weirdest side effect: when the key switch is left in the default (0-degree or up-and-down) position, I have wavy interference or artifacts on the display and it gets worse at higher resolutions.
But when I turn the switch to SECURE (which disables the keyboard and mouse), everything is normal!
I took the beast apart last night and unplugging the key lock from the logic board has no effect, but I didn't expect it to after other threads pointed out the position is "remembered" once set, even if disconnected.
In taking out the power supply, I took a quick look and didn't see any obvious electrical damage but that's way out of my wheelhouse. I know tantalum capacitors can burn out but I haven't an idea what to check next.
This appears to be the only side effect but I'm not 100% sure yet.
Thanks!
Thanks!
