Alaska's Collection
360alaska
Hello All,
         I have finally decided to start a thread... I'm going to start with recently acquired Macintosh II:
I got it on ebay for 10 + 30 shipping. Unfortunately, it had dead batteries so it wouldn't turn on... I went ahead and retrofitted battery holders in this guy:
FYI: The battery holders don't fit into the holes and are too wide next to each other. I was able to make one battery hold fit into the holes by bending out the leads, the other I ended up attaching to the board with silicone rtv and used 24 gauge wire. What the red stuff you might ask? It's insulating varnish:
Yep, I put some under these holders to protect the board in the event of battery leakage... The official retrofit board had a 1000uf 10v Capacitor and I'm not quite sure what it's for but I did add it in...
360alaska
Unfortunately,this one did not come with the FDHD kit :( so I'm sorta making my own kit. The roms are for the MAC II FDHD/IIx/IIcx are the same so I put up a request for a dead IIcx board. I'm sure you could make them on your own with the right gear or maybe ask Rob Braun or BMOW. Next was the SWIM, the Mac II/IIx has a tiny PLCC-28 IWM that is only shared with the IIGS as far as I know. Mac Classics/SE30/IICX/ETC have a larger PLCC-44 SWIM that simply will not fit...  I did some research and discovered that the DIP-28 Mac SE Swim actually has the same pinout as the Mac II IWM so I made an adapter:
Unfortunately, all I had on hand was a 40 pin dip socket but the Swim seems to work perfectly... I'm waiting on a new video card because the original Macintosh II video card only outputs composite sync for the original NTSC monitor... I barely see it it but with the floppy emu I can make it boot 7.0... More to come...
Floofies
Maker of Logos
Wow! Very cool! I'm loving this thread so far, can't wait to see more   ;)
360alaska
So I ordered a video card off ebay an it turned out to be a dud :( I powered on the MAC II and this is what I got:
YUCK! nice and gooey! I suspected that my attention should go towards this guy:
After cleaning, re-flowing, and checking continuity I got it a little better:
I suspect that multiplexer may be bad but in the mean time I have another nubus card on order. It did work well enough that I was able to verify that my SWIM modification worked perfectly. I also tested the 5.25 40mb hard drive and found an old copy of 7.0 on it:
More to come...
360alaska
Well, the other day I got the damaged IICX logic board so I used my hot air station to remove all 4 roms and popped them into my Macintosh II (IICX/FDHD MAC II have the same roms). I plugged in my Floppy EMU and was able to verify the 1.44 mb disks worked! I went ahead and installed system 6.0.8, I've actually never seen system 6 in color since there are just a few models that support 6 which can output color:
I'm also impressed that after all this time this 40mb 5.25 hard disk still works:
One more thing: I have decided to design a pcb to convert the PLCC-28 socket over to DIP28. What I have with the wires works (of course) but it kinda looks messy and I have 1 more MAC II coming my way so I'm doing a run of 3 of each:
This adapter doesn't convert the socket itself, it converts the footprint so you'd still have to de-solder the plcc-28 socket...
Hotdog Zanzibar
Wow... I wish I understood that stuff. I've always been a design guy, but I also have an interest in how these things work.
360alaska
Sorry for taking so long to make a new post, I have built and installed the new adapter and it works beautifully:
This concludes my Mac II project for now...
360alaska
Up next, What could this be?
It's an original Macintosh in near mint condition and all original. I got it with the case for the price of free :)
His serial number is F4424ML0001 which means he's the 5358th manufactured during the 42d week of 1984 in Fremont, CA.
I took him out and tested him only to find the floppy drive is stuck in the down position :(
This part was sticking, I took the mechanism off the rest and cleaned off the old grease and it works now thankfully.
falen5
hey alaska - good stuff.
first time i tried to fix one of thoes floppy drives it took me for ever to figure out what was wrong. Was the same problem you had there. That dam little swing arm. Took a pliars and a good bit to force to move it then paitence and wd40
almost every other 400k floppy i have got my hands had the same problem.
worth the effort when the test floppy finally seats into position and the mechanisim is all clicking together correctly.
free 128!!!......way to go man!!
360alaska
I can't really say I have much to report, I just finished moving and decided to recap my two IIFXs today. I did find it interesting that while one logic board had many surface mount electrolytics the other only had 2:
They did have the same part number :)
I also decided that the best way to store my working compact macs would be to put them on a metal shelf in the living room for all to see:
tanaquil
Nice!! I love to see old Macs out on display, and kitties are always a bonus.
I need to get my Mac IIfx out of the basement. It's been languishing too long.
360alaska
My latest fiind is a 15 dollar (+28 shipping) titanium Powerbook G4:
I bought this guy hoping it would a 1ghz model and by the pictures it looked to be in pretty good shape, but when I received it I discovered the top case had hairline cracks (in the white area) and the bottom case had dents :( . I set out to find replacements and to my luck ebay seller "sunshineex" had brand new top covers, palm rest assemblies, and bottom covers. I ordered them and proceeded to power him up only to discover that the unit did work but it would not put out any sound! In an attempt to diagnose the problem I tried to plug in some headphones only to discover that they would not go in! shit! Despite not having a spare ide hard drive I went ahead and booted the an OS 9.2 universal image from "Mac os 9 lives"  and opened the system profiler only to discover that it was an 867 mhz model :( Double Shit! Well, I also noticed that "sunshineex" had a BRAND NEW 1 GHZ LOGIC BOARD FOR 35 DOLLARS! NICE!
I went ahead and tore her down and reassembled with new body panels and a new logic board, Ifixit was a big help with thier screw guide. I ordered a CF to IDE converter and a 64gb CF card, when I get the os installed I'll post pics. I'm also considering upgrading the 1x superdrive and I hear you can swap the silver keys from the aluminum powerbooks onto a Tibook's keyboard so I might do that. :)
Stay tuned!
CC_333
Great find!
I have a Titaniium PowerBook that was originally 867 MHz, but it was upgraded to 1GHz, although it doesn't seem to be working properly (it kernel panics when I use it for much of anything that puts any sort of load on the CPU), so I think it needs to be replaced. At least the hinges are in decent shape, aside from being somewhat stiff (I'll have to figure them out at some point).
c
360alaska
Great find!
c
Sounds like whoever upgraded yours didn't apply thermal compound, are your fans spinning?
