ants
I’ve had an idea for a while to add Wi-Fi to my Classic Mac. I finally got around to putting it together and I think it turned out really well!
I thought I’d post my experiences here for anybody interested.
There was no hope of me building a PDS Wi-Fi card from scratch - but I already had a DaynaPort E/SI30 Ethernet card so I thought that I might be able to attach a Wi-Fi Bridge to the existing card via the RJ45 port. My first thought was an Arduino Yun board, which has both an Ethernet port and Wi-Fi built in – but they’re expensive, and to me it seemed overkill to use an entire Arduino/Linux solution for this. Instead, I found this Vonets VM300 Wi-Fi Module on eBay for $25 from China! At that price, I thought it was worth trying:
Avocado for scale as I was out of bananas – it’s tiny!
It might look daunting, but it’s very easy to set up – you plug in the Ethernet cable and connect to your Wi-Fi network via it’s inbuilt web interface:
I did the initial setup on my Laptop and I was connected to my Wi-Fi network in no time. But when I tried connecting the module to my Mac, it just wouldn’t connect - all I got was a blinking link light:
After a bit of web searching it became apparent that this is a common problem: modern Ethernet devices use auto-negotiate to detect the speed & duplex of the connection. The old Mac network cards pre-date this standard, so the router doesn’t detect the connection. The only way to correct the issue is to disable auto-negotiate on the router and explicitly set the connection to 10mbs / half-duplex. The issue is that virtually all modern routers don’t allow you to do this, and a first glance the Vonets VM300 was no exception - I couldn’t find any options to manually set the connection type.
I thought all was lost and I’d just wasted $25… until I found the “Upgrade Firmware” button – and BOOM a new drop-down menu appeared!
The instant I changed to 10mbs / half-duplex, the link light on the Mac went solid! A huge thanks to Vonets for adding this feature as obviously it’s a very niche requirement.
My Mac was on the Wi-Fi! Now I just need to mount the Wi-Fi card inside my Mac to make things nice and clean.
I bought a small sheet of aluminium from my local hobby shop, and I designed a basic template to cut it to size – I’ve attached the PDF template to this post. Cutting the aluminium was easy, just glue on the template and score the edges with a utility knife:
Then clamp the aluminium to keep it flat, then bend the other side back and forth a few times until it snaps off cleanly. Next, I drilled some holes and bent the aluminium into a 90-degree bracket:
I bought some 5mm spacers, 15mm M3 screws, bolts & washers from my local Jaycar Electronics (for the Aussies out there), and started assembling everything:
Looks good and very sturdy! I then mounted the completed assembly into the Mac:
I noticed that the Ethernet cable was precariously close to the CRT board, so I ended up angling up the bracket a few more degrees which worked a treat.
The final problem to solve was power to the Wi-Fi card. The card comes with a USB power cable, which conveniently connects via an InLine DC connector (5V) – so I decided to build a replacement cable that would work in the Mac. I already have a SCSI2SD V6 card in my mac, which uses a 4-pin Mini-Molex connector for power - so I found this cable on eBay:
Now I can power both the SCSI2SD and the Wi-Fi card. Funny story: I ordered this part on eBay and literally 15 minutes later my doorbell rang and a guy handed the part to me – weird! Molex connectors have both a 5v and 12v line in them, so I was very careful to only wire up the 5v line as otherwise my board would be fried. This was my finished cable:
A soldering iron was required, and I insulated the 4-pin connector with a bit of hot glue. If you’re in Australia, the Jaycar part numbers are HM3414 for the 4-pin Mini-Molex, and PS0526 for the DC connector (it took me forever to find these!)
I plugged everything in and powered up the Mac – the Link Light came on solid on the DaynaPort card, and the blue lights came on the Wi-Fi card – a quick check in the Open Transport control panel showed that I was on the network – success!
I put the case back on, and I now have a Wi-Fi Mac. It works incredibly well – as soon as the machine boots up, it connects via DHCP to our home router and it’s on the network straight away
Next Steps
I’m a Software Dev, so I’m keen to write a System Extension to display a Wi-Fi icon in the menu bar to manage the connections – just like you would on a modern Mac. I believe that you can communicate with the Vonets module via Telnet to manage the Wi-Fi networks.
I’m new to Classic Mac programming though (not a lot of demand haha) – so it will take me a while to brush up on my C skills!
Next Steps
