sfiera
I recently found a guide for ADB to M0100 mouse conversion [Japanese]. Here’s its schematic for the ADB Mouse II:
Translations:
Above the image, it notes that the red circles are direct connections, but the corresponding white circles are equivalent and easier for soldering.
Has anyone tried this sort of conversion? ADB mice are much easier to find, and I rather like the ADB II. It hadn’t occurred to me that you could to this, but it makes sense. Internally, I guess ADB mice still read the mouse ball with quadrature encoding, so if you bypass the chip, you get the M0100 protocol.
Translations:
- A, Bはどちらでも可: Either A/B is OK [orientation on the mouse switch doesn’t matter]
- 基板上のJA, JBピンをはずす: Remove pins JA and JB from the original board [these are for the mouse switch, which you connect separately]
- コネクタ端面: facing connector end [but I assume the pin numbering is a better guide]
