Scott Squires
So, the ADB protocol actually has room in it for a 2nd mouse button. But I doubt the system software will acknowledge that it exists. What did the 2-button mice you're thinking of do with the second button? I used a Kensington trackball that had two buttons (and later four). You used the Kensington software to define what the extra buttons did. Ctrl-click probably makes the most sense. (Or was it option-click?) That is a bit fiddly because I'll have to queue up a series of events to happen in a certain order, from separate adb devices. Perfectly doable, it's just not he way the code is structured right now.
I was also planning to do something with the scroll wheel. Probably arrow keys.
