CelGen
So I pulled out a spare Quadra 700 and am trying to get an install of A/UX going. So far in terms of hit and miss there's been a lot of misses.
I started by installing 3.0.1. I partitioned it correctly on a 1gb drive and made the mac partition extra large (128mb) for extra software and stuff. The install went smoothly and I did end up with a useable system but the tune-up packages are confusing me.
So officially they are known as Tune-up 1 (two disks) and Tune-up 2 (one disk). Tune-up 1 updates to 3.0.2. Tune-up 2 updates to 3.11 but requires 3.1 and recommends the "AWS Software Upgrade" in order to proceed if you do not have 3.1. I cannot find this, assuming it was some free update in between the tune-ups.
Anyways, even applying tune-up 1 caused everything to go sideways. The machine now boots but the moment A/UX kicks in the screen begins freaking out and the ADB stops responding. Eventually you're dumped to a text prompt because A/UX has given up fighting with the Toolbox for some reason and there's nothing I can do from there because with no ADB the keyboard is dead. Did I simply apply the patch incorrectly?
