foetoid
Been a while since I've been on the forums. Picked up a Quadra 610, full 040, 64Mb of RAM and a ZuluSCSI and decided to go down the A/UX rabbit hole for the first time since the early 00's.
Learning lots from reading posts, and utilizing online resources. Was really excited to see the drop in for SCS2SD, sadly the ZuluSCSI firmware isn't currently fully compatible with all the options in the XML file, so I wasn't able to port that over.
I did most my initial 3.1.1 install on QEMU and then dropped the image on the SD card and fired it up. (After swapping the 040 enabler for version 1.1 of course)
Since I'm going through the pain of doing all of the Jagubox updates, ports, and patches as well as some of nleymann's stuff, I thought I'd throw together a shell script folks could use from a fresh install.
Still a work in progress. Just got started on all of this last night, but what's in the script so far is validated for A/UX 3.1.1. Right now, I'm focused on getting Jagubox done. There's some comments at the top of the script that explain where it's expecting stuff to be located on your system. More to come, but feel free to check it out as is for now. Waaaaay past my bedtime.
https://github.com/corymalon/Apple_AUX_3.1.1_Setup
