So based on your suggestion I looked at what was available on ebay. I saw this 6100 av and thought it may already have a card. I asked to see a picture of the inside and noticed what looks like a g3 upgrade. Seller doesn't know its there. I offered him $35 because his shipping was so high at $45 and I won it. Not even sure I care about the other board now. excited to see if that processor upgrade works. I can part out the reset of the machine or just use that board if it works. Thanks for the suggestion. I think I did ok.
Awesome.
Interestingly I think they haven't removed the logicboard cache, which you're meant to. It can cause them to fail to boot. Make sure you do, although it was really difficult to get out of mine.
It's either a Newer Technology upgrade or an older Sonnet, back when they used black heatsinks. I suspect the latter.
Another oddity, I don't know why, but my Sonnet card refuses to boot some OS versions - I forget which. If it crashes when the Sonnet extension loads and you have already removed the cache, try a different OS version.
One last thing - a cool thing with G3 upgrades in Nubus macs is that if you disable the Sonnet extension, it just boots from the 601. I have an Extension Manager set saved called G3 and another called 601. With Extension Manager set up to load before the Sonnet Extension, I can chose to boot using one or the other CPU by holding space bar during startup.
