6100 with 7100/8100 video card?
Greetings everyone! I just found this forum and I'm digging around. I've had no luck finding anything on this specific question, though.
I've got a new to me PowerMac 6100/60 in the mail. I was looking at the 7100/8100 video cards and they look compatible. Without the case top on, they should physically fit. Before I shell out for one of those video cards, then make a 90 degree adapter, does anyone know if they actually work in the 6100? Thanks in advance!
The AV cards do, the HPV cards... are hit and miss. The HPV cards just don't work in some 6100s, not sure why, but also, the VRAM SIMMs can clash with the hard disk.
AV works fine. Rather than making an adapter you can just use a Sonnet G3 upgrade. They act as the 90° bracket.
I have a Sonnet and an AV card in my 6100/66.
I wonder if it is the 60mhz machines the HPVs don't work in.
Thanks for the recommendation on the Sonnet, just not looking to fork out that kind of cash at this point.
macuserman
There was a project on here at one point to replicate the 90degree adapter. I’m not sure what happened to it I think it was successful if I recall. I’ve been testing a bunch of pds cards and I’ve discovered either I have some bad ones or they are starting to need recapping because out of my large stash only 2 cards were 100% functional with no artifacts or lines.
joshc
