just.in.time
Can you use a polishing kit on it, similar to what is used for restoring vehicle headlights?Self note: don't try to sand the IO door, you will juste make it worse.
Credits where it's due: that's resin from JLCPCB. I don't own a 3D PrinterI like the textured translucent plastics. I think it looks great. Nice job.
Did you use FDM or resin?
Good idea, worth a try !Can you use a polishing kit on it, similar to what is used for restoring vehicle headlights?
Did some changes to the bezels, here they are:
Here's an enclosure for a PowerBook PB 1[4-8][0,5]c? li-ion battery I drew. It's expected to be used in conjunction with the locking tab from an original battery. Thread with more details over in the PB forum:
I need to edit this so I can use 5 (or maybe 10) AA size NiCD batteries. Do you have the model on a Fusion360 format you would be willing to send me so I can just cut out the battery holder part? Maybe STEP or OBJ would work too?
I just made a new pack yesterday. Ended up modeling one myself since I wasn’t able to edit the STL. I made two packs. One with 10 1,000mah NiCd AA batteries which gets around 1.5 hrs runtime and another with 10, 3,000 maH Nimh batteries that’s getting around 2.5 hrs runtime. I haven’t done load tests to find out exactly that the maH is of these batteries it’s just what the manufacturer is claiming. My guess is the “3,0000” ones are probably closer to 2,000 getting me 4,000mah / 2.5 hrs.
Do you know what models this pack is compatible with? The whole 100 series or just the 180?
