128k vs Rust
Durosity
So picked up a wee 128k Mac for cheap the other day. I could tell from the photos that it was clearly rusty and I didn’t really expect it to be usable, but I wanted it anyway so bought it.
Just got it delivered and cracked it open.. I’ve never seen so much rust before.. it’s so bad the brackets that hold the logic board in place have rusted onto it.
That said the damage to the logic board doesn’t look awful.. I’ve not yet been able to see it in full (I think I’ll need to dremmel the frame off) and there only seems to be superficial rust on the analogue board. This could be an interesting restoration… 1993083F-2E7B-4303-ABF9-E7251593CA56.jpeg
Durosity
Possibly. Or sitting in a damp shed perhaps? It’s certainly not as bad as my twin Maxell bombed IIfx board!
Durosity
Yeah I’ve tried but no joy, but I’ll give it another go before I go to extremes.. although that said I suspect the frame is beyond saving so I’d rather rescue the logic board in as best shape as possible if it comes down to it
joshc
That looks terrible. I wouldn't hold out hope for that one. Looks like water damage. The rust will most likely have damaged the traces unless it is literally only sitting on top of the surface. Hope you didn't pay too much.
Durosity
Well until I can free the motherboard it’s hard to say what the damage is. That said I can do a fair amount of board repairs.. it’s just a question of if it’s worth the time and energy.. but every 128 that can be recovered is probably worth it!
LaPorta
If you just straight out replace the frame and logic board, it could work.
Yeah, that definitely just sat in water. Nothing else would cause that except immersion.
Durosity
Well the logic board doesn’t look *awful* but does have some damage. What’s your thoughts on restoration.. plausible? I’m pretty good with recapping and minor trace repair but I’m guessing this will take a fair bit more than that.
Interestingly it seems to be an original version pre 512k, which I didn’t think shipped outside of the us (I’m UK based and this is a 220v P model)
Given they're not that common over here I'd just make a start on it - you never know, perhaps everything will just fall into place.
Where abouts are you? If you're midlands based you're welcome to give it a swim in my ultrasonic.
It was a good start with this corrosion damaged 475.
Edit - ah, I can see from your profile that you're Up North :)
Well, if you're passing through the offer stands.
What does the bottom of the board look like?
It'll be a project to get it working again, but it might be possible. And it will be satisfying if you do.
bibilit
Probably a good start will be cleaning the board will some white vinegar do get rid of a fair amount of rust and dirt.
Yes first issue of the 128k, the second batch were given the marking 128 / 512
You normally use vinegar to neutralise the alkalinity from a battery. I'd hold off using an acid on water damage as acid promotes corrosion. I'd start with electronics cleaning fluid which has some soapy stuff in it, or a mild solvent like IPA, but suspect IPA won't make inroads into this based on my experience with the water damaged 475 last week.
Durosity
I appreciate the offer! I do need to get an ultrasonic at some point, or possibly make my own. I do have a rather large pile of machines which really do need a full restoration.. I’ve been slowly converting my garage to be suitable for all this work.. but I’ve rather overspent lately!
Pics at the top of the thread. It’s stained, but doesn’t seem horrific.
My worry with this repair is going to be having something to cross reference it with, but I do have a 512k Mac which is fully working, so I’m hoping that will be close enough.
... I'm paying attention, honest. Not sure how I missed that.
The attached may be of use to you. I think this is for the original 128k.
I also may have a spare international AB if you need one for 'repairing one thing at a time', Well, I do have a spare but I'm not sure if it works :) would have to check.
edit: now with attachment
  • 050-0073c_macintosh_logic_board_schematic.pdf
Durosity
ASG chip is marked 8423? @LaPorta 🥲
What’s the significance of this? 🤔
How much would you want for it if you do? I actually have a couple of machines that I can use for that purpose, but I’d actually like another one for a Mac plus that’s missing its one!
and thanks for the schematic, that will be most helpful!
