Quantum Hard Drives - which models can be (reasonably) fixed?
3lectr1cPPC
Not sure whether to put this here or in the lounge...
Most of us know that old Quantum hard drives have rubber bumpers in the head assembly that go sticky and get the heads seized. Some Conner drives did as well, and I've recently heard that Toshiba drives are exhibiting the same problem now as well (laptop drives from the 90s specifically). Many drives can be revived by opening them up and either taping over the sticky rubber or replacing the bumper entirely. I have heard though that many Quantum drives put bumpers under the platters, which while possible to get to with special equipment, isn't possible to fix for most. Which models specifically do this though? It would be useful to have a list of which ones can be fixed, would be good for a wiki page or a page on my website. I recall one of them that did this was the ProDrive ELS or LPS models, can't remember which.
Share your experiences below!
volvo242gt
I wouldn't be surprised if later LPS, Maverick, Fireball, etc, drives also have those bumpers. The LPS170S and 270S drives I have look like the ELS drives externally, whereas my LPS240S drive with the fried controller board is the older design without the under platter bumper.
3lectr1cPPC
I heard somewhere that the first gen Bigfoot drives have them. It wouldn’t surprise me if all of their drives did.
Vasily_A
New member
А simple solution to the problem of a sticky bumper on a Quantum ProDrive ELS:
Since it’s impossible to remove and put back the magnetic disk at home,
I glued a soft stop on the back of the voice coil,
which prevents the heads from touching the damaged bumper.
I doubt that this will be enough for a very long time, but it's better than a completely faulty hdd.
This disc has been working for the first time in this millennium :)
