Any suggestions for replacement rubber 'feet' for the Monitor ///?
Huxley
Hi everyone,
I recently became the owner / caretaker of a shocking large quantity of Apple /// stuff - two CPU's, two Monitor ///'s, a ton of books, floppies, etc. All the gear is in decent shape, but both of the Monitor ///'s are missing at least one or two of their blocky rubber feet, which makes them rather unsteady when perched atop an Apple ///.
Does anyone know of a source for replacement feet for the Monitor ///? Ideally I'd find ones identical to the original parts, but I'm open to alternate suggestions.
Thanks!
Huxley
Huxley
Update: I just purchased a set of feet from this eBay listing. It doesn't specifically state that they're good for the Monitor ///, but the pics look similar enough that it's worth a try. Hope this helps someone else too!
Huxley
ried
I've purchased those for both the Apple /// and the ProFile drive and they work great. Suitable replacements for the originals. Note that they are beveled with a slightly different shape than the Monitor ///'s original feet, which are square - but I doubt anyone cares.
Byrd
Bunnings/Home Depot/insert big hardware store name in your country sell bulk packs of solid colour/black/white rubber feet, all sizes and dimensions for little $. I'm yet to not find a decent match using these packs.
Skate323k137
I do the same. An Amazon assortment of black ones got me through many projects, though the ones in this auction do look pretty specific. Some of the ones I got in the assortment are close enough for Apple IIs which is awesome.
finkmac
NORTHERN TELECOM
Huxley
unfortunate. these can be had for MUCH cheaper from digikey, they're just 3M bumpons.
While not an exact match for what the monitor uses, they do work as a good replacement.
