rabbitholecomputing
Vendor The First
We've received, programmed, and tested our first batch of our new 2.5" version of ZuluSCSI V1.1, suitable for internal use in any SCSI-equipped PowerBook machine, and they're available for purchase today via the above link.
This version of the V1.1 board has user-configurable termination via DIP switch, and uses a microSD card socket. It uses the same firmware as the full-sized ZuluSCSI V1.1, and performs identically. It supports synchronous SCSI. Read throughput will generally max out at about 3.8 megabytes/second, in asynchronous SCSI mode, and faster in synchronous.
That this is the fastest 2.5" SCSI emulation device you can purchase today, to the best of our knowledge.
