Macintosh Classic with horizontal interference
Plasticoat
Hi all,
this has been totally recapped, analogue and logic, but I’m getting what only can be described as interference on screen, both sides.
I expect you’ll tell me it’s a cold joint somewhere, I just cannot narrow it down,
any help would be much appreciated,
thanks
Plasticoat
Ok so problem solved, PP1 Phier replaced,
wht da ya know ;)
Plasticoat
Not being sarcastic , the compact Mac forum, I did a search and from what I remember I was kinda pointed in that direction .
you may want to de solder pp1 and apply fresh solder, It cannot hurt, I now replace as I have a small batch at hand so have made it part of the routine 👍
