What did I just win on eBay?
mg.man
Ahhh... I *knew* it looked familiar. I don't have a discrete picture, but here's a shot of the back end of one I recently restored.
The two 2-pin headers go to a "eject" switch (for non-Mac use) and "in use" LED.
olePigeon
As others have mentioned, it's the connector board for the external floppy. @Johnnya101 @Nixontheknight The second floppy header actually connects to the external floppy cable (the cable that ultimately connects to the computer.) The female connector on the board is for daisy-chaining.
@jajan547 The little adapter board is still useful, though. It gives you real LED r/w status for any floppy drive. So if you stuff it somewhere between your floppy drive and your Mac's motherboard, you can route some LEDs to the front of your case and get real LED action. I did it on my IIci (fits perfectly under the drive cage.)
jajan547
Now that’s something I gotta try. Was also wondering would this add DB19 capabilities if connected to a floppy port say for instance on machines that don’t have a DB19?
jeremywork
This is an easily reversible mod and I think it's slick on any system that isn't trying to look historically accurate... Hopefully a simpler version can be recreated so viable A9M0106 enclosures aren't needed. I was lucky to find a lot auction which included one ruined case and a second with internal plastic bits rattling around, but I'd feel bad making this permanent if I hadn't had such an opportunity.
ArmorAlley
That might work in an SE if you have a harddisk in the upper bay and are not making use of the PDS slot at the back.
It might be a bit short through.
If it did work, it would give those with a second external floppy drive a chance to use two of them, or allow for an external floppy drive and a Floppy EMU.
