The Cayman Gatorbox series are AppleTalk routers with lots of bells and whistles, like being able to proxy NFS shares to AFP and being able to proxy PAP printers to lpr clients on Ethernet. I got mine out to play with AirTalk interop testing, and thought I'd take it to bits to check what state it's in inside (mine was actually a barn find, I think: it was covered in hay when I got it and some of the finer hay had got inside—either that or it was beard hair, which I prefer not to contemplate too closely). While I had it open I thought I'd take a photo for you folks.
Everything is on one board, and here it is:
Some very brief notes:
- It's a 68000.
- The serial circuitry which drives LocalTalk and the serial port is very, very close to a Mac's, presumably for maximum compatibility? It uses an 8530 SCC and what I think are the same RS485 drivers. Even at the time this was far from inevitable; there were other serial controllers that could do SDLC-type framing, and plenty of options for RS485.
- The two bits that physically use the most of the board are the Ethernet interface (at the bottom right) and the flash and ROMs (bottom left, above the SIMM slots all the way up to the CPU). There's an interestingly homogenous set of ROM-like things: the two labelled EPROMs are, I assume, the boot ROMs, because they are only ultra-violet erasable. Below them, and above and to the right are some Intel flash chips, which I believe contain the application code. The device is flash-upgradeable over LocalTalk, so this would make sense. In fact, the first revision of that didn't store its firmware on board at all, and had to load it from a TFTP server, which sounds inconvenient. The EEPROM (top left, under the CPU), by a process of elimination, presumably contains the bitstreams for...
- ... the two AT&T FPGAs. I'm not sure why I was surprised to find these here, perhaps because this is fundamentally a router with only two physical interfaces, one of which is restricted to 230kbit/sec. I assume these are used for doing fast-path stuff on the Ethernet side: they're right next to the Ethernet gubbins, and let's face it, it's not hard for even a fairly slow CPU to keep up with LocalTalk.
