Are Mac flybacks interchangeable?
psa425
I have a Mac Plus which appears to have a dead flyback. Can I source one from a SE/30 analog parts board? Are specs the same, are they interchangeable?
desertrout
Yep!
SE/30 will be the 'latest' compact you can scavenge from though - I believe the Classics onward use a differently specced FT
epooch
Do note that the contacts on the flyback may be spaced differently, but the plus analog board should have a ring of contacts for either size.
