The original power supply is rated for 8 amps (224 watts) and I'm not really sure why it would need that much power.
The lineup of Apple Studio Display that plugs into an ADC port includes this beast:
Okay then I think that rules out the Kycon mini-din as that is 8.90mm:Here’s’a close-up photo:
The outer diameter of the ring is 10.2mm
Hope that helps…
Ooo... I have a dodgy Cube PSU - needs to be warmed up to work - so have been following this thread. I believe I also have an old PSU like this I can lift the cable from and avoid cannibalising the Cube PSU. Thanks for the find!!an old power supply (from a broken external FireWire disk)
Excellent, very interested to hear of the results. One of the things that made me hesitant to buy a cube is the PSU that's bound to croak sooner than later with any level of usage.
