elemenoh
I have a nice condition Woz edition IIgs with ROM 01 (342-00770-B) that fails its self test with "System bad 06010000". I understand that means there's a read/write issue to the serial IC.
The solder joints of the Zilog SCC looked good under a microscope but I flooded with flux and reflowed anyway. No change.
I tested pin 23 for clock signal with a scope and that looks okay too. Photo below.
There are no passives near the SCC on my board, but I did a cursory check of the electrolytic caps across the board with an ESR meter. They all seem fine.
Would the likely culprit be the SCC chip itself? Anything else to check first?
This IIgs already has a super serial card, so I suspect the original owner might have had the same issue. The computer is in such nice condition that I'd love to fix this and make it 100% perfect.
