Hi...
I found this list of components for the analog board of a Color Classic (no version number given).
I am trying to buy diodes for my analog board. I am not having any luck.
Reading Techknight's post - color classic mod the correct way:
He says:
DL21 and DL22 get removed and replaced with single 18V Zener at DL21. BZX85C18
Here is a list of parts (plus diodes) for the CC analog board:
http://www.colourclassicfaq.com/tech/ccparts.html
The above list is from the Color Classic FAQ:
Here are the diodes listed from above:
DL5 MR10 120E
DP1 4A Bridge rectifier
DP19 U820 9250
DP22 TL431CLP
DV1 1N301 (ECG177 - Dig-Key)
DV11 Bgf (E?) 1G G1 - SMD diode
DV6 1N301
My CC analog board is part number 820-0360-C.
I don't think anyone has done the mod on a version "C" analog board.
Here are the diodes I could find on my revision "C" board:
DL-15
DP-4
DP-6
DL-17
DF-2
DL-7 - near flyback
DL-8 -near flyback
DL-21-
DL-22
DP-17
DP-18
DP-7
Can someone tell me the difference between a DL diode and a DP diode?
Can someone point me to a part number I can use to replace the diodes above?
Still no luck finding a schematic for the analog board....
Most of the diodes are too small for me to make out any lettering. How do you find the part number??
mraroid
