finkmac
NORTHERN TELECOM
I just got a few PowerBook 500 series power adapters, so I'm finally able to use the 540c and test the 2.5" SCSI2SD I received a few months ago.
It works fine for the most part, however…
Anything that involves the disk spinning down causes the machine to freeze. This could be the default automatic spindown (5 minutes of inactivity I think), manual spindown (via the control strip), automatic sleep, or manual sleep.
I'm guessing this isn't an issue on older PowerBooks, as they don't spin down the disk when sleeping from what I can tell.
Is there a configuration option I should be settings here?
