MacintoshProblems:P
Hello,
so I recently found some old macintosh computers lying around so I wanted to see if I could make any of them boot and work. After a lot of tinkering (and re-capping it twice), I decided that I really don't know what's causing the issue and I can't find anyone that has/had the same issue as me! It boots fine, system is great and doesn't seem to have any issues. The fan spins up and I can hear the Beep although before booting there's this pattern of lines which I can't quite figure out what is causing the issue.
I'll put some images so you guys can see what is happening, if you see that there are lines on the crt it's because of the matching frame rate of the camera and the screen.
Cheers!
Cheers!
