eharmon
I've installed a Lapis (Pro?)ColorServer (8?), in my SE/30 and I'm seeing weird behavior, some good, some bad:
Interestingly, the Macintosh Garden driver archive includes a copy of the Monitors control panel for 7.5.5 so I tried replacing the original copy with that and adding in the extensions but that doesn't seem to help.
I did find this thread by cheesestraws referencing similar behavior, but again, it happens even with no driver at all, so I'm not really sure something deeper isn't happening here: https://68kmla.org/bb/index.php?threads/lapis-procolorserver-24-ii-and-system-7-5.34297/
Further, a later edition of the manual for the LC version(also on Macintosh Garden) references 7.5 and still has SE/30 installation instructions, so it definitely seems to be compatible, but I can't seem to find the right combination of drivers to make 7.5 happy.
The card seem curious, they have an onboard EPROM, I dumped mine and sure enough it specifically references 640x480. There's another ROM image floating out there for what looks like the 8*16 model, which is slightly different.
I'm not really aware of how PDS operates, but is the boot ROM actually augmented by the card's ROM? I notice what look kinda like drivers in the device ROM itself, I'm wondering if they conflict directly with memory space used by Rominator (there's one in there) or something 7.5 simply doesn't expect? That makes me curious if an EPROM upgrade might actually fix the issue (mine is dated 92, the one from the internet is 93).
Any thoughts?
- Contrary to internet reports, it doesn't appear to require a driver to work at a basic level. Immediately from the boot screen the external display is used, which is nice. Whoever owned it last also has it set on 640x480 67Hz so it fortunately works over VGA.
- When booting 7.1, it appears in Monitors control panel as a generic 8-bit 640x480 display and the color depth can be configured normally. It sees both monitors.
- However, 7.5.5 hangs at boot. It makes it all the way to the desktop and deadlocks. The mouse can be moved but Finder never loads.
- If you load without extensions, it boots fully but running the Monitors control panel manifests the same behavior. The mouse can be moved but Finder no longer responds.
Any thoughts?
