Any recommendations for a replacement RIFA cap for a mac 128k? Thanks.
M MacTopus29 Active member Sep 25, 2022 #1 Any recommendations for a replacement RIFA cap for a mac 128k? Thanks.
Nixontheknight Well-known member Sep 25, 2022 #2 Any X2 or Y2 rated capacitor should work as a replacement for the rifa
M MacTopus29 Active member Sep 25, 2022 #3 Nixontheknight said: Any X2 or Y2 rated capacitor should work as a replacement for the rifa Click to expand... Ok
68kPlus Well-known member Sep 27, 2022 #4 I believe the 128k needs 4700pf capacitors (if it's international that is). I used 4700pf ones from RIFA (now Kemet), as they were exact replacements. There is a larger RIFA, but sometimes it's a red cap which doesn't need replacement.
