looking for Info about Flyback for Classic II
saxonas
New member
Hi guys i hope you can help.
I have an Apple Classic II which im trying to restore.The problem is that i cant find a replacement for the flyback.Any ideas for a replacement part or maybe compatible flyback with different serial ?
thank you !
saxonas
New member
Agreed, is there a purple glow with lights off?
Yes its bad.I checked it and it is shorted and when I removed it, measurements at it's pins are between 2,9 and 4,9ohms.
The irf640 mosfet also is gone...cooked...
jajan547
Is it possible to measure and tell me if you find the same readings?(see images)
Not at home right now but know for a fact the one I have works, I can measure mine when I get home but the one I have is yours for $25
jajan547
Yeah mine read different on every pin you tested. Here's a pic of what I have.
Hi Everyone! I'm a new member here; and unfortunately I have the same problem from Mr. Saxonas.; the difference is that I need a flyback to my CLASSIC from 1991. When I turn on my Mac; they are doing strangers sounds coming from the flyback; and on the screens it's possible to see some flashing vertically. It's possible to solve trying to weld again or I'll need a new flyback? Please let me know! iZier.
jajan547
Do me a favor here and take a picture of the back of your analog board.
saxonas
New member
After changing the HOT transistor, the LOPT from JanJan (thank you!), recaping the power supply and METICULOUSLY (I can't stress this enough) cleaning the motherboard, you can see the result! (yes, it's in greek).
