A/UX on a Quadra 605?
fegos
Hi all, i have replaced my Q605 CPU with the one i had in my broken 840av. So it is running at 25Mhz WITH FPU. The Q605 is not listed in the compatibility list for A/UX. Is it dead in the water or is there anything that can be done to install it with some workaround?
afraid not: there are missing drivers for hardware in the 605 in A/UX, so even if you can con it into booting, you can't see anything or interact with it in any meaningful way.
fegos
well yes, that is on my list. I will do the overclocking. I also happen to have a one of those QuadDoublers, it runs but it gets very hot (this one does not have a fan, just a heatsink) and after a while the computer crashes....guessing some sort of temperature protection
