Scott Squires
It's setup to fit directly on top of a Pi Zero-W
Something to do with my rpi zero-ws that I come home with every time I make a trip to Micro Center. That's a win.
The microcontroller connects to the RPi's UART pins. It requires a UART that supports hardware flow control, so you have to do some configuration to make sure that's what's connected to the UART pins on the expansion connector (which may differ depending on which RPi you're using). Details of the protocol are here: https://github.com/lampmerchant/tashtalk/blob/main/documentation/protocol.md - let me know if there's anything I should add there.How does the hardware currently present itself to the system?
\o/ Huzzah!15 TashTalkHat PCBs are now in production
FWIW, I just went through the thread; and assuming that I didn't miss anybody; 11 of 15 hats are currently spoken for.
Yup, you’re on the list.If that doesn't include me, it should. I'd like to be in the queue too.
@bdurbrow am I? I'd like two. I messaged you here a while back but got no responseYup, you’re on the list.
Odd... I did respond to that; I don't know why you didn't get the response (forum glitch???); and yes, you are on my spreadsheet. Also, in answer to your other question from that - I'm not using JLC's assembly services; I'm doing the soldering myself. JLC is the manufacturer of the bare PCBs, though.@bdurbrow am I? I'd like two. I messaged you here a while back but got no response
68KMLA user | Quantity Requested |
Bdurbrow | 1 |
TashTari | 2 |
Mactjaap | 2 |
Aperezbios | 2 |
CircuitBored | 1 |
CheeseStraws | 1 |
Lisa2 | 1 |
Scott Squires | 1 |
NJRoadfan | 1 |
Not a problem.@bdurbrow If it is not too late, could you please reserve a board for me?
Many thanks either way,
Andrew
The secret is I'm using software I wrote myself. It's still got quite a few rough edges on it (undo is... somewhat unreliable) but it lets me lay out a simple board very quickly.Hurrah! I'm really impressed with the speed with which you've generated this hat. Millinery obviously your thing ;-)
