Newtpaint FULL version?
PB145B
Does anyone know where the full version of Newtpaint can be had? The demo is readily available, but it’s pretty useless since it expires after a while.
Thanks!
aladds
Give these a try, I haven't tested either of them so I can't guarantee this is what you want...
Edit: re-attach files (seems that .image and .hqx aren't allowed?)
  • N2.zip
PB145B
The disk image in that zip file contained the full version! Thank you very much! My MP120 is very happy now. 😄
PerspexSphinx
New member
Wow thanks, I’ve been looking for the full version of NewtPaint™ for quite a while. Installed it on Einstein (Newton emulator) works like a charm.
aladds
If I'm honest I can't remember where this came from. I was a member of the NTLK mailing list back when I used a MP2100 as my daily driver, so it's possible it came from there or someone on there. If we think it might not be legitimate to have this here then I'm totally ok with it being removed (although seemingly I can't do that myself)
The other option is we try to contact LandWare (or whoever they are now) and ask them to officially release it - there is a precedent, since a number of old Newton applications have been released as open source now (e.g. NewtCard, NSBasic)
beachycove
Landware products, like Catamount, etc., seem to have required a serial after x days, so if this software doesn’t, perhaps it has indeed been released into the wild. I’m pretty sure their Lunar Lander game was….
It’s hard to keep track of Newton software, as it‘s all over the place and the unna repository isn’t at all up to date.
newtonsales
New member
hi! the image file that contains the full version of newtpaint, how does one open that? i have tried on my mac and it does not recognize it?
splorp
  • Change the file extension from .image to .img
  • Open Disk Utility
  • Choose Images > Convert…
  • Select the .img file and Click “Choose”
The legacy disk image will be converted to a .dmg file which can be mounted in newer versions of macOS.
newtonsales
New member
  • Open Disk Utility
hi, i get an error when i try this. :(
splorp
I was able to convert the image file using Disk Utility under High Sierra.
My guess is that support for HFS images was dropped in newer versions of Disk Utility.
