The beige G3 logic board that wouldn't die (Beige G3 µATX build)
demik
Hello,
This is a little bit of a blog post, if this is more suited to "The Lounge", please let me know.
This is the story of my longest running Macintosh (nicknamed Pulse), which is still running 24/7 after 17 years.
Intro
A while ago, circa 2002-2003, an apple reseller gave me a dead G3/233 Desktop. When I said "dead", I mean it wouldn't boot and half of it was missing:
- Top of the case was missing
- The whisper personality card shield was missing
- Case was bent, was probably dropped
- No RAM
- No HDD, No Optical Drive
Repair procedure
As I needed a new file server (my Performa 6400 was dying), I though it would be a good idea to repair it. The Mac was not starting, but after trying with RAM borrowed from a Pentium III and an ATX PSU, I heard the chime but the display cas scrambled.
The VRAM extension card was defective, I managed to reflow it in a kitchen oven, and put it later on my MT/300 G3 as VRAM isn't really needed on a server.
There you go, it was sort of alive again.
I needed some sort of storage backend and decided to go with a combo of SCSI and hardware SATA RAID (SATA for OS + Files, Using old SCSI drives as backup). I was so impressed with the performance that I upgraded the CPU with a Sonnet Encore G3 500/1M (https://everymac.com/upgrade_cards/sonnettech/encore_g3/encore_g3_500.html). System bus was overclocked at 83 MHz (83 * 6 = 500 MHz)
It ran for a few years on a bad ATX case stacked on a top of rack, thinking it would die a few months after.
New Case / Rebuild
More than 10 years later (2016), being impressed that this Mac was still running, I decided to put it back together in a more clean build. The chosen case was a white cube : Corsair Carbide Air 240.
The motherboard was almost fitting without too much issues
I had to cut a little bit of the backpannel to fit the SCSI Connector :
It got a new PSU for this occasion.
Current configuration
The current configuration is as follow
- MB : Apple PowerMac Gossamer Logic board
- CPU : Sonnet Encore G3 500/1M
- Bus : 83 Mhz
- RAM : 640 MB
- OS : Mac OS 8.1 (Bootstrap + Maintenance) + Linux Debian 8 (Custom Kernel)
- SCSI : Onboard SCSI (for external disks) + Adaptec PowerDomain 2940UW (flashed from a PC Card)
- SATA : Bootable Silicon Image 3112 + Hardware RAID Module (stolen from an external RAID Array)
- High end ATX PSU (don't remember which one, probably Enermax or Corsair branded)
An inside view:
- The blue led board is the hardware SATA RAID Controller
- The CPU coller comes from an Athlon XP system, with the fan removed
Usage
Today it's still used and has no time to sleep : It's used as a file server (Netatalk), DLNA Server (Audio), DNS cache, DHCP server, SSH Gateway and Syslog server.
It gained an Apple Logo on a front, courtesy of a broken Quadra 800 Front panel
Here is a little Linux output :
Code:
 demik@pulse  ~  cat /proc/cpuinfo
processor	: 0
cpu		: 740/750
temperature 	: 27-29 C (uncalibrated)
clock		: 501.150000MHz
revision	: 131.2 (pvr 0008 8302)
bogomips	: 33.41
timebase	: 16707866
platform	: PowerMac
model		: Power Macintosh
machine		: Power Macintosh
motherboard	: AAPL,Gossamer MacRISC
detected as	: 48 (PowerMac G3 (Gossamer))
pmac flags	: 00000000
L2 cache	: 1024K unified pipelined-syncro-burst
pmac-generation	: OldWorld
Memory		: 640 MB
Conclusion
If I can think of a series that can continue to run on standard "PC" parts, this is the Gossamer Logic Board. Everything can be found easily even today. My PowerMac G5s are dying left and right, and I've yet to see a Gossamer logic board to fail. Sure, there is the occasional VRM cap to replace, and I need to replace the fans soon. (bearings are shot)
The PPC750 is also a very simple and stable CPU. One of the best designed CPU of it's erra. It has few bugs online modern x86 counterparts. Thats also part of why it's running on Mars since almost 10 years (https://en.wikipedia.org/wiki/Curiosity_(rover))
Will keep this one up for science until the motherboard dies :)
CircuitBored
This is tremendously cool, possibly the best-loved G3 ever when it comes to your dedication in prolonging its life. I love seeing a machine that's lived a long and useful life.
I'd be wary of survivorship bias though: I know from personal experience that the Gossamer boards can develop flaky solder connections on the expansion slots over time. That said, I've seen it suggested a few times that running a computer 24/7 tends to be better for its longevity than turning it off at the end of each day and allowing it to cool down. My Quicksilver G4 ran flawlessly 24/7 for over a decade yet immediately became an unreliable heap once I put it on a daily power plan. The solder on the RAM slots had cracked and wreaked havoc.
The G3 is such a glorious halfway house between technological eras. The step up from the 604 was immense yet the G4 came and stomped on it so soon after its birth. I'd love to see a homebrew logic board for G3s emerge some day - that would be such a fun low-power tinkering machine.
demik
Thanks for the input ! I only saw the flaky connections on G5 and some late G4s, will keep an eye on it.
You are spot on with the 24/7 longevity. Maybe that's why this one is still running. Another important thing is that there is very few heat produced by a gossamer logic board. Power Wall consumption is under 50W on my system.
Heat play a major role on solder connections.
Unfortunately this is less true on today computers, because they heat a lot more (excluding Apple M1) and with dynamic power features it's like you are putting on a power plan multiples times a day...
As for the home-brew logic board, it was done by the Amiga Community under the Pegasos name (https://en.wikipedia.org/wiki/Pegasos
The G3 processor doesn't look like to be produced anymore. The G4 is (MPC7448 at least), but prices are a bit on the expensive side (up to $500 a single unit). Then there is the soldering problem, soldering BGA components is kinda hard (well there is the oven trick, but soldering $500 components in your kitchen oven isn't something that many will do).
That would be cool, but technically difficult for a home-brew board.
This is really nice.  Especially the Apple logo.  Well done.
Will third the fact that power cycling is enormously harder on machines than just running them all the time.  I've always assumed this is thermal stress but have never looked into it deeply.
joshc
This is really interesting. I have often wondered about how to best adapt an ATX case to some of these Mac logicboards. I really like your implementation, thanks for sharing it!
demik
Thanks. I'm bad at cursing thing straight though...
Thanks ! From my experience G3 and early G4 Motherboards are easy to adapt, though you will need to do new fixing holes.
Those crazy Amiga fans! Thanks for the heads up on that - I'll get on the hunt. It'll probably take half a decade but I'm sure one will show up on ebay eventually...
Speaking of which, if you need a home-brew G3/G4, maybe you can start with a G3/G4 motherboard ? They are plenty of Sawtooth and similar motherboards for like $10 on eBay and QS 733 MHz CPUs are around the same price. They play with ATX PSU just fine if you do an harness adapter.
Cory5412
Daring Pioneer of the Future
Staff member
This is really cool, although I'll admit I was a little sad when I got to the part where it's doing AppleShare services using Netatalk instead of AppleShare IP or even Mac OS X/Server 10.2.
What's the RAID module do? Are you presenting a larger volume to the SIL3112 or does it mostly just offer SATA splitting?
I have thought about doing something similar to this, although using a dA/QS motherboard and several SIL3112s, mostly to keep the QS02 I'm running AppleShare on going a bit longer.
Kaa
This is very cool! I actually just order a bench frame for my G3 Tower MOBO and plan on something similar. Right now it runs an IDE to Compact flash for a drive. Can you elaborate any on your SATA setup for your system? I would love to run SATA drives on this computer.
demik
Small update as that machine needed maintenance this month.
First all the fans were replaced mid 2022 as most of the original ones seized. Ended up choosing Enermax T.B.s since I only trust theses and Noctuas long term. Also no RGB vomit.
465 days later, services stopped forking and one could see this in the kernel logs:
Code:
xfs corruption of in-memory data detected. shutting down filesystem
No good. Given the age of the machine, than can be everything. Surface tested all three drives and that was ok. So probably the RAID controller acting up or some sort of kernel bug.
xfs_repaired all drives, recompiled the latest 4.14 kernel and this G3 was back on track.
Don't even know for how long the SATA drives are running, as the SMART counters rolled over.
A SCSI drive was added later as a temp device and displays as follow:
Code:
smartctl 6.4 2014-10-07 r4002 [ppc-linux-4.14.333-g3] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
Current Drive Temperature:     49 C
Drive Trip Temperature:        65 C
Manufactured in week 40 of year 2003
Specified cycle count over device lifetime:  10000
Accumulated start-stop cycles:  364
Elements in grown defect list: 0
Vendor (Seagate/Hitachi) factory information
  number of hours powered up = 107276.25
  number of minutes until next internal SMART test = 9
Beginning to think it may need a recap someday :)
Sorry for resurrecting this thread, but not seeing a personality card in any of the photos, did you ever fit one? I'm wondering about clearences on the rear openings.
The sound chip is on the card, so I guess that means you don't have any sound?
I believe later versions of Mac OS (9 certainly) crash when they load that Audio extension if you don't have one, but 8.1 does seem to boot.
demik
No worries
I do not have one at the moment because it now has server duties and is indeed booting Linux / 8.1 just fine.
However you are right, that may have clearance issues.
What I did back then is grab another personality card from eBay, remove the jack and put pin headers where the jack where. That way I could use the case HDAUDIO/AC97 front panel jacks.
Horror picture below :
No worries
Cheers.
Even without the ports, having a card in there would let the onboard speaker work. That would be a good ballance perhaps.
