Lithium Polymer battery for PB100 (and maybe portable)
techknight
Thats kind of oddball.... That leaves alot of room for error because the computer cant really use the battery pack as a part of the load if the AC Adatper gets weak. Not to mention switching.
I would say use a boost converter, but we would need a clear way to tell if your into charge mode or not. Since, the load and charge are on the same terminals. could create this weird feedback scenario.
360alaska
Exactly! This is the only way I know how to make it work, but for a computer model that has not had any working batteries for sale in quite a while it's probably not a big deal to have to shut down before disconnecting, if you don't it's not like the computer is damaged or anything. Maybe I can use a small supercap, but how would I isolate it from the comparitor? I've thought about connecting an AND gate to the Status pins on each charger so the relay will open when both chargers give the signal but this battery is good enough.
techknight
Well as long as it works properly and there are no ill-side effects, then its fine I suppose.
I dont use my portable machines enough to warrant replacement batteries, at least not yet. Only functional batteries I have left are my Portable batteries, and I just float them every few months so they dont go bad, I havent used any of the machines for a few years now.
Fizzbinn
Got my PB 100 battery from @360alaska this weekend and after replacing a failed fuse he helped me identify (that I didn’t realize was bad) I’m wire free on a 30 year old laptop! So cool!
sutekh
Very cool! I developed something similar for my Duo (separate thread over in the PowerBook forum), but although that platform has some of its own unique challenges (ID chips, current regulated charging algorithms, etc.), one critical factor made the single port charge / discharge steering easier than what you've overcome here: When plugged into the charger, the Duo's battery terminals see ~20vdc, which gets pulled down by a NiMh when inserted. That allowed for simple diode steering into a battery-internal Li-Ion 3S CC/CV charger (which requires a source voltage over ~13.5vdc to engage) when plugged into AC, but it isn't engaged by the battery alone when it's discharging and AC is unplugged. I have a functional 18650-based pack, but am not nearly brave enough to try selling them :)
I'm now in the process of developing a 2S pack with its own power-path steering circuity for my PowerBook 180c, and while in some ways its characteristics are more conducive (7.5vdc OE charged voltage is a great fit for a 2S Li-Ion's 7.4vdc), the single port charge / discharge switching is more complicated. I'm using a 2S CC/CV charge board (similar to the 3S part I used in the Duo pack), but with only 7.5vdc from the wall charger, a boost converter is necessary in this application (or a split as you've done, very creative!) I can't just let the Li-Ion cells / BMS back feed into the boost converter, and with a common charge / discharge port, some sort of sensing / switching is necessary to prevent that (as you're obviously well aware).
Ingenious approach with the split cells, comparator, and electro-mechanical relay. Love seeing resto-mod projects like this leveraging modern tech to augment these old 68Ks :) In my case, I'm planning to use an LT1494 (or similar) current-sensing opamp to drive the gate on a FET powering the internal boost converter / 2S charger only if current is flowing into to pack. Bench testing currently on-going with a thread to follow if it goes anywhere...
360alaska
Thank you for your encouragement! There was a bit of trial and error and research involved. I'm going to try and use the other half of the comparitor to release the relay when both charging ICs signal complete.
360alaska
Here is my final design:
I added the two 10m pullup resistors and two extra transistors to function as an AND gate to overide the latched comparitor and release the relay when charging is complete. This will also necessitate a small pcb redesign:
KnobsNSwitches
Fantastic, I could not find this thread before...another ebay customer here, eagerly awaiting my replacement battery. (first one had some kind of relay issue, 360alaska was easy to work with.)
I wish i'd know this was here, would have been glad to contact 360alaska directly instead of thru ebay...
Such a cool product and design.
electricmonk
This is cool. I made a LiPo battery for my PowerBook 100 too but I just used a BMS circuit from Aliexpress to regulate the charging of the cells. Managed to cram it all into a 3d printed battery case. It's crude but it works well enough. I love what you've done though, vastly more sophisticated. Is your version still available on eBay?
Trash80toHP_Mini
NIGHT STALKER
DeWalt has a new battery pack system that resembles lithium polymer, but is straight lithium technology. It'll be interesting to follow those developments, the stacked cells appear very well suited to battery mods without the dangers posed by the polymer component?
@360alaska love your work, one day I'll get one for my PB100s too. :)
360alaska
Yes, it is. In fact I'm working on a pb140-180c battery pack using the same circuit.
electricmonk
Ah excellent, I've found your eBay store.
Would you be so kind as to explain in technical terms why the laptop shuts down when you remove the power adapter (if not fully charged)? Because the one I made with a $2 aliexpress BMS doesn't have that problem, but then neither does it charge the battery to 100% I'm sure.
360alaska
Yeah I guess, Basically you can't fully charge your batteries together with a 7.5v charger, you need at least 9 volts to charge a 2-cell lithium battery. In charge mode, my circuit splits the batteries so the can be charged individually, but doing this has the downside of the batteries not being ready if one were to just disconnect the power. With my circuit you must wait for charging to complete, when the charge controllers both signal complete the battery will go into run mode, alternatively, one can shut the laptop off and disconnect power to bring the circuit out of charge mode.
Basically the positive side of a LM358 comparitor is connected to the battery through a diode which is also connected to the battery + and the negative side of the comparitor is connected to the battery directly through a 20k trimpot for tuning. With that setup the comparitor will never output a high signal by itself. The only way to get the high signal is to give a higher voltage on the positive side by connecting a power supply.
If the power supply is not connected the comparitor(+) sees about 6.5v and the (-) sees 7.2v, with the power supply connected the comparitor sees 7.2v on the (-) and 7.5-7.9 on the (+). With this being the case the the opamp triggers the relay which splits the batteries and that means the comparitor will see 7.5-7.9v on the + and 3.7-4.2v on the minus which of course means at that point it is latched and will not reset until the chargers signal complete or power is disconnected. Consider also, when the battery is fully or nearly fully charged the negative side sees 8.4 and the positive side sees 7.5-7.9 with the charger connected or about 7.5v when the charger is disconnected. So in other words, when the battery is at a higher state of charge the lm358 will not give a high signal either but keep in mind that once the battery enters the charging mode the lm358 is latched so even if the battery is fully charged it will not reset until the power supply is disconnected or the chargers signal complete.
alexGS
Thank you for all the information and insights. I am trying to make a Powerbook 100 battery as well. I hoped that perhaps 3.2V LiFePO4 cells would be compatible with the charging voltage, but they don’t have enough voltage to run the Powerbook (which seems odd; I thought 6.4V would be enough - I was using two pairs of 600mAh cells = 1200mAh capacity, perhaps not enough current). The low-battery ‘Good Night’ shutdown is triggered as soon as the Powerbook has started up.
So instead, assuming we use 2x 3.6V Li-ion cells, I am wondering; what if the $2 AliExpress BMS is the boost-type, as linked below? It now becomes possible to charge 2x cells from less than 8.4V, but, I imagine it is still necessary to isolate the cells from the Powerbook while they are charged. I guess this is what Sutekh described before.
For the PowerBook 100, would it need another regulator to drop the ~7.5V supply to 5-6V? - or would the PowerBook’s supply ‘see’ the charging load and stay in the controlled-current, lower-voltage phase of operation that seems to be part of its design?
Your thoughts please :)
