Newton Connection Utilities
mvallance
Hello. I have a basic question.
I wish to connect my PowerBook 1400c / OS8.5 to my Newton 2 via Newton Connection Utilities 2.0.
The obstacle is how to de-select my Stylewriter II printer in the Chooser so that I stop getting the message 'serial port in use' when trying to connect the Newton (via a serial cable and Newton adapter).
Does that make sense? Thank you.
Do you have AppleTalk turned on in the Chooser?  Look at the bottom.  If it's enabled, turn it off and try again?
mvallance
Thank you.  I left my Newton in my university office and now they have gone and locked me out for a week :-(
I will attempt this again later. I will update this thread.
Yes... that worked. I restarted the Powerbook too.
AppleTalk defaults to using the serial port as its network interface.  So if AppleTalk is turned on and you haven't selected the Ethernet port or there is no Ethernet port it will prevent anything else from using it :) .  That's why turning AppleTalk off worked.
