NuCF development (aka, the IIfx is a quirky sod)
zigzagjoe
68060
As I don't have a worklog thread for the NuCF, I suppose it's time to start one. I've finally revisited the NuCF and issue it has on the IIfx; recap is around a year ago I suspected something screwy is going on with the /AS strobe seen by the IO bus and PDS slot. It's generated in a PAL in the 20mhz clock domain used for those subsystems, rather than coming out of the 030. Unfortunately, I was not able to capture the *what* as even putting a scope or LA probe on /AS would suddenly cause it to start working. Hacky fixes like adding some resistance or capacitance would help, but that's ultimately a wretched hack and is just reducing the probability rather than removing the cause.
For that among other reasons the NuCF project went on the shelf for the past year.
I *finally* captured the smoking gun, though. While I still haven't captured /AS directly for lack of an active scope probe, I was instead able to find an indirect and damning symptom. I started from square 1 and started building the logic up from scratch again, and found even the well-tested writing to the flash wasn't working correctly. That's a pretty fundamental issue!
Below is a strobe to the DeclROM on the card. By process of elimination if I swapped it to be a product of /DS instead of /AS, my prior inability to write to flash would clear up. Easy enough to capture on the scope, and would you look at that glitch. It can be inferred that it's worse in actuality since there's propogation delays/hysteresis in the CPLD generating this strobe. My assumption is the actual root cause is likely ringing.
I suppose that's the peril of working with high speed CMOS logic (flash, CPLD, and CF cards) - where the geriatric IO devices on the logic board are too slow to react in time or be disrupted by it, the modern stuff I'm using is fast enough. Remains to be seen how I'll choose to address this, but there's options, at least the cause is *confirmed*, finally.
Some incidental tidbits about bare metal code on IIfx:
Disable ROM overlay, stolen directly from SuperMario source
Code:
#define OSSRomCntl    0x204                    //offset to ROM control register.  Bits are:
#define OSSRomInit    0xD                      // initial value for ROM control register<3.5>
// overlay off, 2 ROM wait states
move.b  #OSSRomInit,(OSSRomCntl+ADDR_OSS)
How to put the SCC IOP into bypass mode for direct access. Also stolen directly from SuperMario. Looks like they tell the IOP to set a couple of its private registers then hang it.
Code:
#define ADDR_SCC_IOP    0x50F04000
#define ADDR_SCC    (ADDR_SCC_IOP+32) /* actual SCC address, in passthrough mode */
#define iopRamAddrH              (0x0000-0x20)               // high byte of shared RAM address register
#define iopRamAddrL              (0x0002-0x20)               // low byte of shared RAM address register
#define iopRamAddr               (iopRamAddrL-1)           // WORD access to shared RAM address register
#define iopRamData               (0x0008-0x20)               // shared RAM data register (byte, word, or long)
#define iopStatCtl               (0x0004-0x20)               // IOP Status and Control register
//   bit numbers within the iopStatCtl register
#define iopInBypassMode          0                       // IOP is in BYPASS mode
#define iopIncEnable             1                       // enable addr pointer increment
#define iopRun                   2                       // 0 -> reset IOP, 1 -> run IOP
#define iopGenInterrupt          3                       // interrupt the IOP
#define iopInt0Active            4                       // interrupt 0 active
#define iopInt1Active            5                       // interrupt 1 active
#define iopBypassIntReq          6                       // peripheral chip interrupt request in bypass mode
#define iopSCCWrReq              7                       // 0 -> SCC REQ active, 1 -> inactive
//   commands bytes to write to the iopStatCtl register
#define resetIopRun              ((0<<iopRun)+(1<<iopInt0Active)+(1<<iopInt1Active)+(1<<iopIncEnable))
#define setIopRun                ((1<<iopRun)+(1<<iopInt0Active)+(1<<iopInt1Active)+(1<<iopIncEnable))
SetSCCIOPBypass:
    movea.l #ADDR_SCC_IOP,%a3
    move.b    #resetIopRun,iopStatCtl(%a3) | init the Status/Ctl reg, hold IOP reset
    | Download the IOP code
    lea     SCCIOPInitCode,%a0        | a0 <- start of IOP code (in this ROM)
    move.w    (%a0)+,%d0                | get the size code (-1 for DBRA)
    move.w    (%a0)+,iopRamAddr(%a3)    | setup the code load address
LoadLoop:
    move.b    (%a0)+,iopRamData(%a3)    | download a byte
    dbra    %d0,LoadLoop            | load all of the bytes
| Start IOP execution
    move.b    #setIopRun,iopStatCtl(%a3) | release IOP reset (let it rip!)
    lsr.w    #6,%d0                    | 0xFFFF -> 0x03FF -> loop 1024 times
wait:
    dbra    %d0,wait                | delay a bit while IOP initializes
    rts                                | return to caller
                                    | 6502 code to throw SCC IOP into bypass mode
SCCIOPInitCode:
    dc.w    (2f-1f)-1                 |    (byte) size of the code
    dc.w    0x8000-(2f-1f)             |    (word) load address
1:                                    |    code starts here
    dc.b    0xA9,0x81                 | 7FEE: lda     #1*DEBUG+0*SCCISM+1*BYPASS
    dc.b    0x8D,0x30,0xF0             | 7FF0: sta     SCCControlReg
    dc.b    0xA9,0x44                 | 7FF3: lda     #SccIOCtlReg
    dc.b    0x8D,0x31,0xF0             | 7FF5: sta     IOControlReg
    dc.b    0x80,0xFE                 | 7FF8: bra     0x7FF8
    dc.b    0xEE,0x7F                 | 7FFA    7FEE    Non-Maskable Interrupt vector
    dc.b    0xEE,0x7F                 | 7FFA    7FEE    Processor reset vector
    dc.b    0xEE,0x7F                 | 7FFA    7FEE    Interrupt Request vector
2:                                    |    code ends here
That is fascinating! Now that I think about it, it surprises me that we haven't encountered more 'defects' that were covered up by old/slow technology.
I am glad you returned to work on the NuCF, given its incredible performance.
How would this manifest on the IIfx? I haven’t seen any issues on my IIfx running the NuCF yet even under a lot of benchmark testing for you a year ago.
It throws errors on certain compact flash cards on certain IIfx computers. For example, I only experienced one (or two?) finicky IIfx computers out of my collection. The others worked fine. And, on the finicky IIfx computers, they worked with a SanDisk Ultra II 2 GB and Verbatim 4 GB, but not any of the other compact flash cards. Those same 'bad' compact flash cards and 'bad' NuCF works fine on the other IIfx computers, as well as the IIsi.
Putting a tiny capacitor (18 to 24 pF) or pull-down resistor on the AS line makes it work on the finicky IIfx. Now we know that helps with the bouncy line.
So, ZigZagJoe could reasonably ship what he has and it would work well for almost everyone. And, we know a simple hack for anyone with an issue.
But, I think he wants to perfect the design, given he is so close and knows what the issue is now for sure.
If you'd not noticed it yet, you are in the clear as far as I am aware. It does not affect all machines. I had a working theory that it was related to certain vendors of PALs for the one that generates the /AS for the IO bus devices but never fully proved that out. Since the implementation of those PALs are each different internally this allows for different drive characteristics and internal timings, so perhaps Apple tested with one type originally and later substituted? There was a guy with a development "F19" board, it'd be interesting to check what that used.
This sums things up exactly. I may as well fix it properly (and some nitpicks I had) even though it'll require a full test run across everything I can manage. I think to fix it in hardware a small RC filter might be enough to take the edge off, but I'll have to simulate and play with values. If i could borrow an active probe to exactly capture what was going on, that'd be better still, but I'll settle for tested and working.
In truth it's nothing wrong with the CF cards; it's just that some are more tolerant of glitches on their read/write strobes than others. I've found most CF cards seem to operate in their highest possible speed mode at all times (including slew rate on their outputs - buffering and termination highly recommended!) so it'd make sense that they really can't deal with glitches that'd otherwise be tolerable. The flash I used for the DeclROM is also intolerant of those glitches, so affected machines would be also unable to update the ROM if that were to ever be required.
Adding resistance or capacitance at the destination isn't all that hacky.
Unless you want to mod the logic board, you don't control transmission line tuning at the source/PAL.
Maybe older logic had greater input capacitance that masked the issue.
Adding termination or filtering in a controlled fashion is normal to address something like this. What i call hacky is to add random pulls or bits of capacitance without understanding why the issue is fixed, or how large the margins are. Sometimes it is unavoidable, or too difficult to quantify, but it's better to understand first when possible.
I suspect it's a mix of the older logic being more tolerant and also not seeing the worst of the (presumed) ringing being nearer to the source. I don't think every single IO device sees this strobe either.
