I once removed the antiglare film from an AppleVision 1710 after it had become damaged. I suspect yours will be the same but as the linked article says, it will be obvious once you have the CRT removed from the bezel.If the problem is just the anti-glare film, that would be awesome! I will try to remove it anyway. Thanks for the link @KURB, that is very useful!
It’s quite good to know you can actually get replacement film of this sort.
