Yes, I realise that, although some tasks are also small and repetitive. Different things are different, so a consistent workload, nicely broken down like in System Info can be informative regarding the strengths and weaknesses of a system and helps comparing.One does need to be careful with benchmarks vis-a-vis real world performance since it depends a lot on the particular test's working set. If it's all in internal L1 caches, it'll show a huge improvement, but if you're spending a lot of time poking RAM, not as much....
That's a bit daft. If you're going to put four slots on a 32bit bussed processor. Weird to hobble your accelerator when you need to compete with other vendors.Yeah, per Micromac it's a 16 bit RAM bus on those accelerators, reinforced by it permitting SIMMs to be installed in pairs. A strange choice for sure.
