Page Buffer Capture from Radius FPD/SE VRAM Input - First baby step to cloning Card
Trash80toHP_Mini
NIGHT STALKER
68040
Some folks have been wondering about what I've been posting a related thread over on TD. I've been using that as a Development Notebook, so here goes the first release of the project:
Developing a carrier board to interface with the first gen Radius FPD/SE's four VRAM Chips. They'll be de-soldered and then inserted into wire wrap sockets installed in their place. From those pins, wire wrap makes all the connections on this prototype carrier board. Ask about details if interested. Right now I'm wondering if anyone can decipher the two approaches to Pi GPIO input I'm aiming to do from these flow chart diagrams:
First, I need to determine in what order the data lines need to be hooked up to GPIO so the 16bit word (register/whatever) makes sense. So attempting to use parallel inputs as a sort of logic analyzer setup to determine ordering of the sixteen lines in the first step:
When I can figure out which lines need to be hooked up to which pins on the DeMux IC and then switched to outputs leading into the PISO chip it will convert the sixteen parallel inputs to a single serial input and on to a single GPIO pin of the Pi Zero 2 W.
So the overall, inscrutable carrier board logic flow chart/diagram looks like this . . . craziest pic for last:
Assumption is that things like CAS, RAS and other signals on the VRAM will need to head into the Pi GPIO pins at some point? Serial input on a single line frees up 15 GPIO inputs for such fun and games!
Please comment on this:
- does the visual presentation make any kind of sense?
- If so, does my approach to the data line ordering problem make any kind of sense?
- traditional schematic development will be notated one wire wrap connection at a time . . . it's a prototype!
Aim at the moment is to get the same image output via Pi's HDMI output as I get from the Card itself, comparing one screen to the other. After that, image rotation will be simple enough, if slow with dropped frames on Pi. Project is aimed at implementation in FPGA and eventual cloning of the card therein. Titans of FPGA development have said "the project seems 100% viable."
So I'll need a lot of of help . . .
Radius FPD/SE is 640x864, 1 bit per pixel, 51 MHz pixel clock. Is that correct, or near correct?
Are you capturing writes to VRAM, or reads from VRAM? Are you capturing reads from CPU or the reads from the display output side?
You said "VRAM input" so that probably means you are capturing writes to VRAM.
Why not capture the stream from the display output side? You wouldn't need a PISO in that case. How fast can the Pi GPIO serial input be?
Maybe you are capturing writes to VRAM to save processing time? How fast can writes to VRAM happen? The Radius FPD/SE is a PDS card so the writes are probably CPU bound and also not limited by a slower bus such as NuBus.
Does the card have any acceleration? If it did, then there would be writes from the card's controller.
For the visual presentation, you could make more clear that the 16-bit 1-2 Demux is controlled by the Serial/Parallel GPIO switch.
Explain why there's only 8 address lines?
640x864 1bpp = 69120 bytes.
Does the display have 1024x864 hardware panning?
1024x864 1bpp = 110592 byte.
What does VRAM 4x64 mean? You have a photo of the Radius FPD/SE at:
https://tinkerdifferent.com/threads/radius-macintosh-se-full-page-display-pictures.4893/
Are those NEC D41264C-12 DRAM chips?
64Kbits x 4 = 256 Kbits.
256Kb x 4 = 128 KB which is the minimum required for 640x864 and 1024x864 1bpp.
The datasheet for the D41264C shows 8 address lines. I guess they're used for both column and row select to address the full range.
The datasheet shows 256 rows, 1024 columns (256x4). That fully utilizes the 8 address bits (2^8 = 256) for both row and column select.
The -12 in the part number means 120ns which is the row access time. The serial access time is 40ns.
Close enough I guess?
Capturing full Page Buffer from Data Inputs to VRAM.
Output side's wonky, Page Buffer capture from VRAM input keeps everything in the digital realm for output via HDMI->DVI conversion pigtail connection to obsolete Displays lacking HDMI inputs.
Dunno, 16bit at 8MHz PDS vs 32Bit Nubus at 10MHz seems close to a wash to me?
No acceleration in first gen VidCards for the B&W only Compacts, so no worries.
Nap, simple three header jumper selection does the down and dirty in hardware, no Pi involvement whatsoever. KISS!
edit: one program on the Pi will determine data line load order from parallel inputs. After that everything goes thru the SIPO to free up 15 GPIO Lines for fun & games.
That's from the VRAM pinout, board buzzing looks like this:
Craziness at bottom in purple/green drove me nuts until I realized the VRAM ICs were "upside down" and addressing on lines above became clear thereafter.
Display's a solid 864x640, no panning involved. @trag ran the numbers and VRAM on board has more than enough capacity to store the entire frame buffer. VRAM overage would be a function of getting enough space to do the job.
Here's a much better pic:
Yep, all of the above, but there are CAS and RAS pins on the chips, dunno how they might be involved?
Figuring writes to VRAM would be the wedge I need to crack this wide open? In the eventual FPGA iteration, the inputs will be double buffered in FPGA, so lag time should be limited to just one screen draw period. When that part's done, the FPGA will swallow the rest of the card whole. ;)
Here's where I made my breakthru. None of the SBC based VGA boards are up to doing image rotation, so I came up with this plan:
Zero 2 W will almost certainly be too slow to do rotation in real time. A low end Pi 5 CPU is Quad Core and 4.4x faster than the Zero's Single Core, so it just might do the job? After that, FPGA will do it easily in real time.
At present, determining the data line load order for PISO input would be the goal.
Ok, between 51.270 MHz and 57.283 MHz.
HDMI->DVI is a nothing burger. Same pins. Same signals.
For the Output side, you have the serial read port of the VRAM which is probably what gets used for the display output (and also for DRAM refresh?). Those are digital.
57.283 MHz / 16 = 3.5801875 MHz = 279 ns. Could the Pi handle that?
8 MHz is 125 ns. So it might be better to read from the serial read port of the VRAM?
How fast can the SE write a line of pixels? The 68K MOVEM instruction can do half a scan line (320 pixels) using 10 registers. 4 cycles per register is 2 MHz or 500 ns. A normal MOVE instruction is 12 cycles.
So it might be better to read from VRAM input (as you have currently planned) if you can't handle 3.5801875 MHz from the serial read port.
With serial read port you might take advantage of the fact that the bits are read in order from left to right, top to bottom, where as VRAM input is random access.
I didn't mean that the PI was involved. I meant that the three header jumper is used to tell the DeMux where to send the 16 bits.
I don't understand why S0 on the 4 chips would be tied together. I would double check that.
That is indeed a much better picture.
Each VRAM chip addresses 64K of data that is 4 bits wide. addressing 64K of anything requires 16 address bits but the chip only has 8 address bits. The address is divided between rows and columns. When /RAS goes low (falling edge), the 8 address bits select a row. When /CAS goes low, the 8 address bits select a column in the row. A column is 4 bits wide. A row is 256 columns, 1024 bits total.
The timing diagrams show the different types of accesses. You can access multiple columns in a row without having to update the row address (i.e. every /CAS does not need to be preceded by a /RAS).
I guess you need to be able to capture the info described by the writing timing diagrams. It appears that you can capture write data when /WB/WE goes low with a few exceptions:
- Hidden Refresh cycle: when /CAS is low
- Page Read Cycle: when /RAS is low (except this looks a lot like the Page Early and Late Write cycles and Page Read-Modify-Write cycle ...)
I guess you need to find out if those exceptions happen in order to decide if you need to detect them.
The datasheet describes each cycle type. The description for a cycle type should explain how to detect that cycle type if the timing diagram doesn't make that clear enough.
First need to worry about if the Zero 2 W is fast enough to read the row and column and data of every write cycle.
Yep, adapter to full size HDMI and a six inch HDMI->DVI pigtail to mount on the metal bracket are in hand.
Looking to be able to run the card/carrier combo sans VRAM when complete so Frame Buffer capture from VRAM input is the way to go. No need to build VRAM into the FPGA to keep things simple that way.
Dunno, keeping the trick of capturing every second/fourth/eighth/whatever frame for the time being is in the plan. Delaying HDMI/DVI output by enough frames to see where the pixels land on screen is in the playbook. With a long enough delay examining each individual pixel as it's loaded will be oh so cool.
Figuring the data input won't be random, makes no sense in this application. FPD/SE gen one card has no intelligence on board or DAC, so figuring read/write will be in the same order every cycle?
Thanks much! Serial port capture looks like the ticket for noodling out the load order for VRAM lines to PISO? In parallel mode with 16 data and 8 address lines hooked up, I've got only a pair of GPIO lines available. Serial data and "start over" period detection seems like a good approach to load order determination?
Yep, figured as much, but edit window was closed. Hate that nonsense here. If limited, a couple of hours would be so much better for folks to think better of a questionable reply, edit and avoid warnings for such.
Those were the first lines I buzzed, they're on a layer labeled WT*? in AI. Haven't looked at them after got over confusion about chips being "upside down" on the card.
Yep, too bad it's "upside down" as well. Figured that out after I couldn't fix that an repost.:rolleyes:
Thanks for looking into all the angles. It'll take me ages to decipher this.
That would be where capturing intermittent cycles comes into play. I'm prototyping the process in wire wrap, notating a "real" schematic one wrap at a time. Pi 5 with four times the Cores running at 2.4 times the speed might not even get that job done. Hopefully Pi5 will be able to capture and rotate enough alternateX frames that flicker won't be horrific in this feasiblity study.
Such would be why I thought of doing it in FPGA and bounced the notion off our resident wizards of the realm. ;)
I guess I should explain the point of the overly complicated wire wrap prototype. Aiming toward doing a PCB set up like so.
To run the adapter sans VRAM, only the sense line on the board's connector needs to be shorted. Likely will need to be shorted to run output through the Extron Scaler anyway.
Clarification: sense line on the board's connector pins needs to be shorted to run output from the connector/cable through the Extron Scaler when VRAM is present in system. If not shorted to ground, INIT is not installed because no FPD Display connection is detected.
Journey started in previous thread about the Pre-SE/Slot Manager Version of the FPD Card I began using as a development notebook.
To the Mac SE system software, the VRAM needs to behave exactly like normal RAM. To draw a single pixel, the CPU will use a MOVE instruction to read the surrounding 16 or 32 pixels into a data register (1bit per pixel). Then modify a bit in the data register. Then write the result back to VRAM.
You must capture every write to VRAM, otherwise your copy of the framebuffer in the Pi will be incomplete. The Mac SE writes pixels to VRAM like it's an offscreen framebuffer in RAM except this is for an onscreen framebuffer. It writes when something is being drawn - a menu, a cursor, a window, an icon, whatever.
Maybe your rotate transform can display the Pi's internal copy of the framebuffer only at a reduced rate.
The data input will be random. It's a framebuffer that the CPU writes to. The cursor might be drawn at any position on the screen every vertical blank. The position is random. The user may click on any menu. That's random.
Read and write happen in any order. They are just 68K CPU instructions. MOVE, MOVEM, etc.
We don't know that the serial port gets used yet (it should, else why use this dual port VRAM chip when a single port RAM chip would work?) You're buzzing result of SO0 is weird.
If you're set on capturing VRAM input, then get the order from that as you originally planned. If you decide to research the serial output side, then that would be interesting.
You might decide to capture PDS input instead of VRAM input.
If you don't have enough GPIO pins to do one test of 16 data bits, you can do two tests of 8 data bits each.
Actually, instead of reading 1 data bit at a time from a PISO, you might consider reading 8 data bits at a time. I think that has the same level of difficulty as using a PISO? In either case, you have to create a clock. 16 cycles for the PISO or 2 cycles for the 8-bit parallel input. The clock has to be fast enough so that it doesn't last longer than the data is valid. Actually, you could latch the 16 bits, and clock the first 8 bits on the falling edge of /WE and clock the second 8 bits on the rising edge of /WE?
The chips have the dot or indent to show which side has pin 1.
Preview.app has the Rotate Left and Rotate Right menu commands. For comparing the backside and frontside traces of a PCB, Preview.app has the Flip Vertically and Flip Horizontally menu commands.
Need to capture all the cycles, otherwise your local copy of the framebuffer will be incomplete/wrong.
Maybe you should begin by counting how fast the write cycles happen to the VRAM. Just use a counter to count falling transitions of the /RAS and /CAS and /WE lines.
Have you researched how fast the Pi can read serial or parallel data?
I am thinking you might be trying to do MHz stuff on a platform that can only do kHz stuff?
GPIO interrupts might be too slow. Maybe polling in a tight loop is faster to find when a GPIO bit changes? How fast can the Pi poll and test the bits?
